Old 08-15-2022, 10:37 AM
Stoby's Avatar
Stoby Stoby is offline
Bronze Level Site Supporter
Default 300 Crank ?
Anyone know of or recommend a complete crank to buy?
Old 08-15-2022, 02:25 PM
You will pay through the nose for a new OEM crank, if you can find one. I would consider having your crank re-built, if possible.
I would try Hall's or Motocenter and see what the cost and lead time are.
Good luck!
What year is the bike?
Old 08-15-2022, 09:19 PM
Stoby's Avatar
Its an 09 engine that I want to redo since I have gear issue . This is going into my 18 before it blows up (the 18) hopefully. I was just hoping to find a wrench rabbit kit etc.
Old 08-15-2022, 09:32 PM
https://www.ebay.com/itm/18548367490...3ABFBMmrW5xNRg
Old 08-22-2022, 11:59 AM
Just curious why you would not re-build the 2018 motor? Do you plan on changing the mounts on the 2018 frame to accommodate the 2009 motor?
Old 08-22-2022, 02:10 PM
Stoby's Avatar
Default Shite !
that ruins my plans . I didn't know the cases were different from 09 to now. I just want to do a quick swap so my bike isnt sidelined. I had no idea the cases had changed since the middle years. I thought they only changed 03-04ish
Old 08-23-2022, 12:12 PM
Someone may correct me, but I believe the frame/motor mount design has changed at least three times since 09. 10-11', 12'-17' (may be a change somewhere in this time period as well) and the newest design 18'-present (rieju).
I would start cross referencing parts and see what can be used from the '09 motor. You could use the 09 as a donor motor, which may help with costs and downtime for the rebuild on the '18.
Old 08-24-2022, 07:04 PM
A quick check of center case gasket part numbers should tell you if the mounts are in the same spots.
Old 08-25-2022, 11:39 AM
Center case gasket part #:
2009- ME120144001
2011- ME250544001
2012- ME90000013012
2018- ME94000GG-CLJ-1
crank jmdcr50 Enduro Engine - 2 stroke 7 03-26-2015 10:16 PM
Crank Remover and Crank Installer tools for EC250 Fabry Enduro Engine - 2 stroke 5 06-25-2013 08:24 PM
gas gas ec 200 crank chinesegav United Kingdom 5 11-27-2012 07:49 PM
Crank it up! Rick Pictures & Videos 2 04-09-2011 01:36 PM
