Go Back   Rieju & GasGas Legacy Riders Club Forum > GasGas Enduro Technical Forums > Enduro Product Announcements
Enduro Product Announcements Announce new gasgas enduro products here - Vendors Welcome...
Old 06-22-2013, 02:18 PM
celler celler is offline
I also purchsed one of these for my 300. I wanted to see if it softened the hit when the power valve opened. I now have about 200 miles of riding with it including dry hard clay/rock, mud and water, and perfect sand. Overall I liked it. It controlled the hit somewhat and I did not notice any other negatives. I have a Rekluse so the stalling was not an issue before. Response to clutch was still good. Now the good news. I thought since it was taming the hit I would try lower 13 -50 gearing. I tried this gearing once before but in the slick hard rocks I would regularly get more wheel spin than with the 13-48. So anyway. With the weight the 13-50 really worked well. Put the Map switch to sum mode and it really responded smoothly to the clutch. In the rain mode sayed very smooth and linear. I run a Suzuki needle for reference. So was it in my head or was it real? Average Speed on my 20 mile loop 17.7. Fastest I have ever had before 17.3; today was not ideal traction (but ok) and everything is really green hampering visual lead. I think the rearing gave me the speed but the flywheel let me use the gearing. I recomend if you ride where traction is not ideal.
Old 03-21-2014, 10:03 AM
jmd jmd is offline
Just ordered one. Sounds like exactly what I was looking for. Thanks.
Old 03-23-2014, 11:42 AM
Ud_luz's Avatar
Ud_luz Ud_luz is offline
Originally Posted by GMP View Post
I can't imagine anything that heavy. I can see it in Europe though, where a lot of guys grow up on trials bikes.
Actually the exact opposite. You want instant throttle response on a trials bike. Any delay can really screw you up.
04 Montesa 315R, 07 EC300, 21 KTM Erzberg 300, 21 Sherco 300 SEF-F, 23 KTM 690, 23 Rieju Mr Pro 300
Old 03-23-2014, 11:22 PM
StuJohnson's Avatar
StuJohnson StuJohnson is offline
Still one of the best mods on my bike!!!
2012 - XC 300 Racing
Seattle, WA
Old 03-24-2014, 01:06 PM
hannesd hannesd is offline
don't they rev it first and then snap the clutch to get instant power?
trial bike have a heavy flywheel indeed (as far as i know).
Hannes.
Old 03-24-2014, 10:04 PM
sweeper sweeper is offline
Banned
Hannes.
Correct.
Old 03-24-2014, 10:46 PM
Ud_luz's Avatar
For the displacement the flywheel, at least in my Montesa, is smaller than most enduros.
Old 03-24-2014, 11:56 PM
Banned
Also correct.
The trials bike engine internalizes a lot of the crank effect in the crank itself.Coupled with a bore and stroke designed to rev quickly and smoothly just off idle.They don't rev really.Very low rpm in comparison to moto or modern enduro/offroad racing 2 stroke engines.
Its about torque.
The old trials bikes did have monster flywheels.
The thought I had after reading through the thread.How much weight can the engine handle out on the end of the crank.23 ounces is a lot of weight out there for an engine that is designed to really spool it up.
Bearing,case wise.What's to much?
Old 03-25-2014, 08:50 AM
Ud_luz's Avatar
Originally Posted by sweeper View Post
Also correct.
Its about torque.
I would think if it's correctly balanced the additional weight shouldn't be an issue.
Old 03-25-2014, 09:56 AM
Banned
Same rider who adds 23 ounces of flywheel weight to the bike isn't gonna be a guy that keeps it spooled up all day.Its a riding style modification.Some relief their to the added stresses to the original engine design.
If I was contemplating that mod,I would cross reference main bearings and rod bearing sizes between a trials bike engine with approximate cc as what I was modifying.
Factor in the trials bike is much lighter.And is designed to run at a lower rpm with an intake,exhaust and electrical system designed for smooth almost electric acceleration and decceleration.There is no hit and the engine will only rev so high.
There is a cutoff somewhere to how much weight you can add and still expect the lower end to hold up.
flywheel weights davedunaway General Discussions & Announcements 6 01-28-2011 02:52 PM
flywheel weights kokusan generator Caravan Monster All Other Bikes... 5 06-14-2010 11:21 PM
Flywheel weights biggstr6 General Discussions & Announcements 21 03-30-2010 10:54 AM
Flywheel Weights??? DAGWOOD1971 General Discussions & Announcements 4 06-15-2007 11:15 AM
