Old 07-23-2009, 03:39 PM
Dunk's Avatar
Dunk Dunk is offline
Default Correct plug?
My 300sm has a B10EGV in it, is this correct?
'01 Gasser 300 Supermotard
'99 KTM 200 EXC
Old 07-23-2009, 06:38 PM
slocalspode's Avatar
That seems a bit cold to me, but, if you ride the bike
hard on the throttle in high in the RPMs. That just
might be in the ball park.
Let's wait and see what the real knowledgeable folks
here have to say. As I am interested in stuff like this
also.
Jeff So. Cal. USA
Old 07-23-2009, 06:40 PM
MattR's Avatar
MattR MattR is offline
I'm not familar with that number. What brand spark plug?
I use NGK spark plugs. The EC250/300 should use a BR8EG (fine electrode) or BR8ES (standard electrode).
NGK also makes an iridium plug BR8EIX. This is what I'm using now. It provides a stronger spark for better burn.
Here is the NGK spark plug reference chart.
http://www.gasgasrider.org/NGKsparkplug_chart.gif
EDIT:
From the chart, it looks like "B10EGV" is as follows:
B = 14mm thread (correct)
no "R" = non-resistor type
10 = Colder than stock (GG recommended = 8)
E = 19mm thread reach (correct)
GV = Gold-palladium V-type electrode ($$)
Matt
Current: 2009 Yamaha FZ1
Old 07-23-2009, 08:08 PM
jostby jostby is offline
For some reason I would "flame out" or foul every BR*** plug I tried. Back then my kid rode slow and it always happened after long slow downhill sections. Pour the power on and "poof"! I now run B8EG, same plug now for 7 years. (yeah, I'm cheap ) The non-resistor plug has worked well for me.
'00 XC250 (mine)
'04 EC250 (the kids)
Old 07-24-2009, 09:13 AM
I always thought the # in the middle, ie 2-10 refered
to the plugs heat range.
This is where I got that idea from.
http://www.kaila.net/tl125/tl125ngkcode.html
correct me if I am wrong. thanks.
Jeff So Cal. USA
Old 07-24-2009, 10:33 AM
MattR's Avatar
Jeff So Cal. USA
Oops! you are correct. I read the NGK chart wrong. I editted my previous post. Thanks.
Matt
this may not be the correct place to ask, but... compmoto SouthEast United States 6 10-30-2010 02:10 PM
Spark plug gasgas125sm08 Enduro Engine - 2 stroke 0 03-08-2010 09:42 AM
2T drain plug wence Enduro Engine - 2 stroke 0 10-13-2009 04:28 AM
Fork seals, Do I have them installed correct ramcclure200 Enduro Suspension 10 04-17-2008 12:00 PM
correct jetting for my 01 xc200 ? fasternat Enduro Intake/Carburetion - 2 stroke 4 02-28-2007 12:19 PM
