Old 06-07-2021, 03:04 AM
bvacher bvacher is offline
Default Help! Stumped?? Kickstart jam 98 ec250
Hi All,
Im stumped - need help. This is the problem:
After a recent rebuild - engine turns over on crank fine - see pic 1. All the gears turn - the crank gear the flywheel gear the clutch basket and the kickstart gears - all turn when I turn the engine,
Pic 2 - when I try the kick start its solid! When I slide the clutch basket off the kickstart and starter cog turn fine and return spring - everything. Then when the clutch basket goes back on - solid with the kickstart!
Old 06-07-2021, 07:44 AM
Do the crank, clutch and balancer rotate ok without the kickstart assembly in place?
Old 06-07-2021, 08:01 AM
yes all rotate normally on the crank
Old 06-07-2021, 04:41 PM
The kick start drive is not "timed " properly.
There's a flat plate that the kick lever gear ramps on, to engage the clutch basket gear.
You can try rotating the kick start gear clockwise a couple degrees.
Old 06-07-2021, 04:43 PM
Assembly should be the same as listed in this manual.
https://www.dropbox.com/s/i93vw77r9k...anual.pdf?dl=0
Old 06-07-2021, 11:40 PM
Banditpowdercoat Banditpowdercoat is offline
Originally Posted by bvacher View Post
Hi All,
What is going on? Any help appreciated...Attachment 9130
Attachment 9131
JUST pulled mine apart 2 days ago, same thing. The shaft angles without the outer cover on and gear hits the clutch.. Put cover on and you will be fine. I was trying to determine a bearing noise and trying to turn with kickstartwe with clutch side all open and felt it jam
Old 07-07-2021, 03:41 PM
I've had the same before, with mine it was the little nylon spacer for the spring had indexed round so the cutout wasn't mating with the spring
2016 RM-Z450
Kickstart ratchet pinion and kickstart spring alignment for tension question Gas Gassin Enduro Engine - 2 stroke 2 01-20-2021 08:52 PM
2015 Ec250 kickstart shaft In U.K Nicktamps "Wanted to Buy" & "Want To Trade" 2 12-02-2019 03:02 AM
Will yzf/wrf 250 kickstart fit my ec250 2001 Crabber94 General Discussions & Announcements 10 06-18-2019 10:26 PM
EC250 2012 kickstart >:( blamir "Wanted to Buy" & "Want To Trade" 8 01-28-2015 04:18 PM
