Old 05-15-2018, 05:42 AM
Bossman_racer Bossman_racer is offline
Default 2010 gasgas ec250 unreal vibrations!!!
Hi all
I?m new hear thought you may be able to help me, I?ve recently bought a 2010 ec250 after reading good reviews I sold my excf450 for this. After going out on it I couldn?t believe the vibrations when revving! To the point after doing 2 miles I couldn?t feel my finger tips! I?ve noticed that there is a leak on the front pipe which could be causing back pressure problems... any help would be appreciated.
Thanks
Ben
Old 05-15-2018, 08:35 AM
2 strokes are notorious vibrators, but try checking that the o-rings on the exhaust flange are not worn, that will make the vibrations worse
Old 05-15-2018, 10:54 AM
Neil E. Neil E. is offline
Check all the engine mounting bolts, swingarm bolt, headstay bolts. What is the history on this bike? Rebuilds? It may have a worn out connecting rod.
Old 05-15-2018, 01:11 PM
If the engine is tight in its mounts, it sounds like something is wrong inside the engine.
Pull the ignition cover and see if you have up and down movement in the crank bearings. Double check your flywheel and flywheel weight.
I had one Steahly FWW that did not play nice with one specific flywheel but the FWW worked fine on another bike. The one flywheel was machined incorrectly with the hole off center from the puller threads, but the flywheel was balance corrected for it so it did not vibrate without the flywheel weight.
Old 05-15-2018, 04:13 PM
Thanks for the replies guys, I?ve checked all the things suggested previously as I?m not new to bikes and building them. I have been out tonight for a decent ride and I think it?s mostly because I am so used to 4 strokes and having raced bikes on road for the past 10 years I?m guessing I?m just not used to a 250 2 stroke. Being honest I think I?m going to put it up for sale and revert back to a 4 stroke.
So if any one is after a bike shout up! 😊 thanks again.
Ben
Ps had a full rebuild 18 hours ago. Plus lots more
Old 05-15-2018, 05:01 PM
I?d be guessing incorrectly pressed crank webs. Especially if it has had a recent rebuild. Stick a dial gauge on the end of the crank and check the runout. I recently pressed one together and the owner said it was never that smooth from new.
P.s 2 stroke do vibrate but never enough to make fingers numb, so something is amiss.
Old 05-15-2018, 06:16 PM
I agree that the crank was probably reassembled incorrectly.
Old 05-15-2018, 08:16 PM
philm philm is offline
My 2010 300 seems to vibrate a lot more than my previous 2006 model so maybe it's something peculiar to 2010 bikes.
My fingers used to go numb after a few minutes of riding but wearing padded palm protectors or inner gloves seems to remove most of the vibrations. They might be worth a try before you sell it.
Sent from my Lenovo TB-8504F using Tapatalk
2010 GasGas EC300 Nambo
Old 05-15-2018, 10:32 PM
My 2010 was a real hummer too. Not so much finger tips but definitely through the pegs.
Double check the head stays, they are known to crack.
Although you have checked the engine mounts go back over them. Loosen em off and work from the swingarm back forward finishing with the head stays. While they are slack compare the frame to the mounts. Some people have found less vibrations if shimming the chassis up a little too.
Usually it's the 300's that buzz more so than the 250's.
Old 05-16-2018, 01:41 AM
I've only ridden 05 and 07 250s. Never remember vibes. My mates 10 300 has more than mine but no drama. I run pro-taper pillow grips which are pretty cool.
Heck a mates 15 WR450 vibrated more (and what a bus).
Crank run out the first thing that came to mind.
Find one at a trail and ask what his is like. He'll offer to compare.
Never trust a full rebuild unless you've done it. Or trust the mechanic.you can imagine the Xbox snot noses working on bikes. Or owners damaging true cranks putting them in. Or the courier.
I've had to sent a crank off to be fixed and welded (last resort) as it was put in uneven and got loose.
2010 GasGas EC250 bazzagas Used Bikes 0 10-22-2013 04:38 PM
2010 GasGas Demo Day at Battle Creek MI May 22, 2010 twowheels General Discussions & Announcements 12 06-14-2010 06:29 AM
Front pipe vibrations? wiking Enduro Engine - 2 stroke 12 08-20-2009 04:57 AM
I'm pickin' up bad vibrations, need new bars? thelonius General Discussions & Announcements 9 06-15-2009 09:43 PM
