Old 02-27-2008, 04:08 PM
quadinfamily quadinfamily is offline
i bought the quad over the internet, I think from someone in KY .It was deliver to Alt Ga about a 2 year. If you think it one of yours let me know , I have a lot of question. give me a call 770 266 2787 thanks joe
Old 02-27-2008, 04:56 PM
Steve@Motowest Steve@Motowest is offline
Originally Posted by PEB View Post
Steve,
I have one of those pistons in a stock size that came out of my current bike when I did my first top end. Does that imply I have a bike that you tuned as well? If so, what else did you do to it?
Paul B
Maybe, I need more information.
Old 02-27-2008, 05:44 PM
PEB PEB is offline
It is an 02 se 250 converted to a 300 at some point. It came to me with that piston in it. It has the 250 ignition box, crank stuffers, had the reed spacer in it. I think it was originally owned by a guy named something Zin in texas. I always was under the impression it was a smackover bike.
Paul B
Old 03-01-2008, 11:39 AM
Originally Posted by quadinfamily View Post
I found the right piston it's from 330 pro x big bore kit for a honda 250r ,and i do have stock cylinder and piston just a little to slow for my taste. 130.00 for piston and rings it cheaper too. thanks for help
You better look closely at the base gasket, if it's one of our engines it must have our custom spacer gasket. Measure the thickness of the one you pulled out.
Old 03-01-2008, 11:47 AM
Steve,
Paul B
Does that mean you are now using the stock GasGas piston without any problems? If so, then somebody just stuck a Honda piston in there, maybe because they couldn't get the correct one?
The pistons we use in our big-bore and long-rod kits look similar but will not fit in a stock engine.
Old 03-01-2008, 11:53 AM
Originally Posted by gasgasman View Post
Hmmmm.......so a person can make his 300 (2 wheeler) a fire breathing 330?!
Hey Girard, our Stage 2 300 kit (non big-bore) adds 20hp at the back wheel.
Old 03-01-2008, 01:25 PM
fury1's Avatar
fury1 fury1 is offline
how much does that kit cost steve?? does the bike still have the ability to run pump gas?
Old 03-01-2008, 03:30 PM
It was originally designed for the quads and included a pipe, which is no longer available but, we can still do the engine work for $1700.00. No pump gas.
Piston A, B or C? wence Enduro Engine - 2 stroke 19 07-06-2010 12:46 AM
250 EC Piston pbspecial Enduro Engine - 2 stroke 6 05-11-2010 06:44 AM
Piston Kit for 99 Gas Gas 300 EC TorbenS40 General Discussions & Announcements 2 04-06-2010 05:44 AM
piston W8TSON Enduro Engine - 2 stroke 1 07-31-2009 12:25 PM
how does my piston look? rupecopp Enduro Engine - 2 stroke 16 06-09-2008 08:09 PM
