Old 09-26-2020, 01:27 PM
gasser's Avatar
gasser gasser is offline
Default 2018 rear axle slot in swingarm
I feel this slot is machined too short - it stops way short of alowing the tire/wheel to be pushed forward to where the tire contacts the shock flap/guard. Cutting that slot only 1/3 inch longer would allow better fine tuning of the wheelbase and, more importantly, make changes to gearing possible without always having to change chain length. Should I attempt to make the slot longer and if so what type of cutter would be best?
Old 09-26-2020, 03:04 PM
Making the slot bigger may weaken the swingarm.
Use a burring bit to remove the aluminum.
https://drillsandcutters.com/sa3nf-3-8-x-3-4-cylindrical-carbide-burr-1-4-shank-aluminum/
2018 axle block pre-orders motocenteraz Enduro Product Announcements 16 02-15-2020 11:50 PM
2018 swing arm / axle adjuster chunkysoup Enduro Chassis & Body 5 05-21-2018 06:47 AM
Swingarm Axle for EC200 Kris Enduro Suspension 0 05-19-2014 07:31 AM
Swingarm axle question??? ktmguy23 Enduro Chassis & Body 12 04-06-2007 11:54 AM
swingarm axle wheels7 Enduro Chassis & Body 19 12-16-2006 09:40 PM
