Spade connectors, what size?
Trying to wire the 2011 style headlight on my 2001. I need to change out the small spade (female) connectors for large ones. My calipers measure the male spades on the headlight at .306 inches/7.8mm. Largest available is 1/4 inch. Where would I get these unusual connectors?
All the wires are here and ready to go, just need to be able to connect them to the headlight. One other question, are these newer headlights meant to have a hi/lo beam switch? |
You can go to the auto parts store and get the right spade connectors. They have a complete connector that plugs into the bulb. Should be the same as the H4 set up.
My '11 didn't have a hi/low switch. No reason why you couldn't use one. |
Ok, that makes more sense.
The only reason I ask about the hi/lo is because there are two bulbs. Will both be lit up all the time then? |
The little "peanut" bulb is a running lamp.
Here's the connector. |
GG 200 size | Darkside | General Discussions & Announcements | 21 | 01-31-2012 10:57 PM |
Wiring and Connectors from '11 eStart SwitchPod | twowheels | Enduro Electrical & Wiring | 2 | 02-02-2011 01:16 PM |
Exposed connectors | pistol | General Discussions & Announcements | 7 | 01-28-2011 09:11 PM |
Nut Size | steve | Enduro Engine - 2 stroke | 2 | 01-11-2008 10:58 AM |
Sealing Electrical Connectors | iancp5 | Enduro Electrical & Wiring | 3 | 11-23-2007 09:58 AM |
