Old 04-05-2015, 08:04 AM
Gibby Gibby is offline
Default 2013 300r spark problems
Went riding yesterday started up and ran fine for about 2 miles and blahh just died. We figured it fouled the plug but when we put a new one in still no spark.
After about 10 more minutes and pushing back toward the truck Tryed it again and if fired up and rode all the way back to truck turned it of at the truck and when I went to recrank no fire. So I disconnected the kill switch and it fired right up so naturally thought that was my problem and got back on the trail, 3 miles in it died again. Intermittent spark problem any suggestions? I hate to buy a CDI if the coil is bad and vise versa. Any hints on how to trouble shoot or any simalar storys with a 2013?
Old 09-20-2015, 06:15 PM
pigpen966 pigpen966 is offline
What was the issue? Sounds exatly what mine started doing yesterday.
Dick Carnes
"If ya run, you'll only die tired"
2019 EC 300
2018 GP 300
2013 XC 300 (sold)
2006 DE 300 (buddy has it)
Old 09-21-2015, 06:50 AM
GLantern's Avatar
GLantern GLantern is offline
Is it an estart or kick only? Just a quick background I have a fuse on mine that will work loose a little under the seat sometimes. When this happens the estart won't crank at all and the bike won't fire when kicking.
Not sure about the 13s but check and see if those are loose before going crazy. Sometimes it's the simple things, just my 2 cents.
Old 09-21-2015, 03:51 PM
MarkPhillips's Avatar
MarkPhillips MarkPhillips is offline
I was having a little trouble myself. Would only run in the mid to WOT and died as it fell to idle. Thought it was my carburetor and cleaning skills. Turns out that the kill switch had rubbed bare UNDER the gas tank against the frame rail. Intermittent spark failure, but the bike could overcome the ground out when running in higher RPM range. Pretty frustrating. Cleaned up the electrical fault and my baby is back. Good luck!
2011 GG EC300
1978 BMW R80
2013 EC250 ?powervavle? problems rubber Jonny Enduro Engine - 2 stroke 30 04-11-2014 03:39 PM
450 vs 300R ???? wa_ndro General Discussions & Announcements 19 05-26-2013 07:26 PM
2013 300R, does the ignition key kill your bike... rgranger Enduro Electrical & Wiring 10 03-21-2013 08:40 PM
2013 300r Binni General Discussions & Announcements 11 10-12-2012 06:54 PM
Spark problems sitaylor2003 Enduro Engine - 2 stroke 2 12-20-2006 12:13 PM
