Old 07-08-2015, 02:38 PM
tday tday is offline
Default 2009 ec 300 kill switch
2009 ec 300 is the kill switch normally open or closed? i just purchased a yamaha yz kill switch and it is normally open. just wanted to make sure it would work?
Old 07-08-2015, 03:27 PM
Anders's Avatar
Anders Anders is offline
it will work. The kill switch usually shorts the ignition signal to ground when pushed.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 07-09-2015, 12:00 PM
Thank you very much i was pretty sure but i had not checked what my old switch was.... Thanks again..
Kill Switch mcnut Parts 0 12-08-2014 06:32 PM
kill switch??? spooly Enduro Electrical & Wiring 29 04-08-2014 01:06 PM
Kill switch wheelie Enduro Electrical & Wiring 2 05-21-2012 07:12 PM
kill switch Rabbitist Enduro Electrical & Wiring 3 05-22-2011 07:07 PM
Kill Switch Dingo Enduro Electrical & Wiring 4 12-10-2008 04:23 PM
