Gas gas ec 300 crank shaft nut
Hi i need help.
I did a general overhaul. I replaced the crankshaft seals. and when I tighten the nut (crank shaft pinion lock nut).there is the opposite thread. I found on the Internet that he needs to be tightened on 98NM. but when I tighten it to approximately 70NM .the crankshaft is very difficult to turn. should it be? can new seals do it? Thanks for help. And sorry f?r my Bad english. |
Help crank shaft play | andrewjtheis | Enduro Engine - 2 stroke | 10 | 05-15-2019 05:56 PM |
GG FSE 450 crank shaft and other parts [rebuild] | V1T0 | Enduro Engine 4 stroke (including EFI & Exhaust) | 8 | 10-27-2018 11:43 PM |
Crank Remover and Crank Installer tools for EC250 | Fabry | Enduro Engine - 2 stroke | 5 | 06-25-2013 07:24 PM |
XC250 2001 Crank shaft Interchange | Zman | Enduro Engine - 2 stroke | 3 | 03-12-2013 09:47 AM |
2001 XC300 Crank shaft bearings | timlh | Enduro Engine - 2 stroke | 0 | 06-23-2010 06:23 PM |
