Old 06-05-2010, 11:23 AM
GMP GMP is online now
Question Tubliss Questions
Just picked up a Tubliss. I know they say start with a new tire, but have any of you used a used tire as long as the bead area was not damaged by the rimlock? I have a couple good used tires I would hate to waste.
Also, whats the story with tire sealant? Recommended or optional? If used whats best? What kind of mess does it make on the insert when its time to swap tires?
I have a couple wheels and plan to set them both up with Tubliss(one with Mitas trials tire) if all goes well with the knobby.
Thanks guys.
Old 06-05-2010, 01:24 PM
stainlesscycle's Avatar
i have run it with non-new tires. it works, sometimes you get slow leaks - you will need to check pressure before you ride. do your best to align old rim lock marks - it helps. if you have 110lbs in the tubliss, it should seal - the most important thing is to have a clean bead, good rimstrip (with their tape), and a good clean bead on the tire.
i don't use sealant. have you encountered puncture flats in the past? sealant would be a mess..
07 ec300
www.stainlesscycle.com
Old 06-05-2010, 04:44 PM
Eric K Eric K is offline
Glenn,
I started with a Tubliss, new tire and no sealant. I run the tire at 5 psi. Over 600 miles later still no slow leaks.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 06-05-2010, 06:35 PM
Skidad's Avatar
Skidad Skidad is offline
I used an MT16 that was about 1/2 worn out that had been fitted with 2 rim locks for my first TuBliss install. Initially it dropped some pressure but to be honset the valve stem was not perfectly straight but I left it anyway. I then pumped it up to about 50psi and left it overnight. It dropped to 40psi by morning. Good enough for me. I then pulled the valve stem and put in TrueGoo sealant and it stayed perfect from them on. I put a gash in the sidewall but the sealant did work although a bunch did work it's way out. I wouldn't run without it but yeah it's messy when you pull the tire. It's so easy to pull the liner I did that to clean everything off. New Pirelli MT43 aired up and held perfect from the get go. 2nd bead was tough to get on with that thing though.
97 KTM 250 EXC (sold)
2016 Trek Remedy 29er
Old 06-05-2010, 07:29 PM
Thanks. No, I never use sealant, just heard it mentioned a lot with Tubliss. I would prefer not to as it seems like it would make a tire change a major time consuming mess. I have an almost new S12 (my sand race tire) and a very good IRC VE33. I'd like to try the VE33 in the rocks at 5-6 PSI. I'll clean up the tire and give it a shot. I could also fill in any imperfections from the rimlock in the inner bead surface with RTV.
Old 06-09-2010, 04:02 PM
HAWKWIND HAWKWIND is offline
Question
Originally Posted by Eric K View Post
Glenn,
Eric, are you still running the X-11?
2006 EC300
Old 06-09-2010, 07:41 PM
roostafish's Avatar
I have also used non new tires, and it works fine as stated, as long as the bead is okay.
I do use Slime sealant. I just like the assurance. My brother in law made me a believer when he had a knob rip off and the slime leaked out, but the air stayed in.
Mike Sheetz
OMRA #21AA
'15 KTM 300 XC-W
Gran Prix Cycle
LTR Suspension
RB-Designs
Old 06-10-2010, 02:07 PM
gasser's Avatar
gasser gasser is offline
I use Slime for a different reason - I use it to protect the Tubliss liner from chafing when running very low pressure - I can run 0-2 pounds with no problems. I've run the Tubliss for more than 100 hours since I mounted it and have had no flats or pinches even though I've averaged less than 4 pounds of air pressure in it.
Old 06-10-2010, 04:33 PM
Cruiser Cruiser is offline
Glenn if you want to soften the bead up on the mix up some brake fluid and water and armor all, equal parts,, wipe on the bead and let sit,, then wipe off.. Its what the monster truck guys used to do to cure slow leaks or reuse tires..
Steve
16 Beta 350rr
04 KTM 525 sx/exc gone
03 GG 250 ec-gone
97 GG 250 ec Gone
Old 06-12-2010, 04:53 AM
I have been running the Metzeler DOT Unicross knobby with the Tubliss on my 06.
I have a Mitas trials tire with a HD tube on my '01.
Eric K
'06 GasGas EC300
'01 GasGas XC300
TuBliss Testimonial twowheels Enduro Product Reviews 30 07-06-2011 09:49 AM
Tubliss with dinged rim GMP Enduro Chassis & Body 2 09-06-2010 05:29 PM
TuBliss roostafish General Discussions & Announcements 30 04-14-2010 12:15 AM
Tubliss ejas66 General Discussions & Announcements 14 12-26-2008 06:59 PM
Trials Tire + Tubliss? MIKEWA Enduro Chassis & Body 7 03-18-2008 06:03 AM
