exhaust splodge
help please,
only recently i noticed i'm getting loads of sploge coming out of exhaust, i'm mixing 125ml oil to 5 litres, some say its the rings that may be going that is causing this,but compression is not down, and others say it's too much oil, but as above theres my mixture,any advice please, ONE MORE THING how can i get a bit more top end power, EC250 2002 MODEL, THANKS, |
i run at 40:1 always with motul 800 or castrol TTS this is a hard thing to answer, but what rev range causes the splooge, my bike does it, but its only in the higher throttle range. like when i do a tight forest track theres virtually no splooge, but a faster farm track or when im on the power more will cause lots of splooge, so i think my jetting is slightly rich in the higher end of the throttle range. could you work out where you think its rich to cause the excess splooge. and i think to make more power, sort the jetting out to get it to run crisper and that should make more power that way could be wrong tho? |
Thread Tools | |
Display Modes | |
ec250 exhaust | woody1965 | Enduro Engine - 2 stroke | 2 | 11-24-2009 03:48 PM |
Exhaust Spacer | GG27 | Enduro Engine - 2 stroke | 3 | 11-24-2009 08:29 AM |
FMF exhaust | gevandam | Enduro Engine 4 stroke (including EFI & Exhaust) | 0 | 04-28-2009 02:48 PM |
09 125 Exhaust? | hasslbri | Enduro Engine - 2 stroke | 2 | 01-28-2009 11:59 AM |
EC 300 Exhaust dB | jyellard | Enduro Engine - 2 stroke | 7 | 09-18-2008 08:30 AM |
