Old 08-05-2009, 11:54 PM
lukemillar's Avatar
lukemillar lukemillar is offline
Default Fuel lines - Inside or outside of frame?
Here is a new one:
My 03 FSE 400 has started leaking fuel and I have traced it to a hole in the fuel line. Basically these lines run from the fuel pump, outside of the frame and to the injector. Where the line goes past the frame, it has rubbed against the plastic tank covers and worn through. The RHS line is showing the same wear, though hasn't started leaking yet
I did a quick search, but couldn't find any similar threads. Should these lines run inside the frame rather than outside? It seems pretty vulnerable to have this setup. I've ordered replacement lines, but I'm wondering if it is just bad design or the old ones have been installed in correctly (they have been like this since I bought the bike)
Thanks
Luke
2006 Triumph Daytona 675
2004 Gas Gas 400 FSE
Old 08-06-2009, 04:59 AM
gasmonkey's Avatar
Bronze Level Site Supporter
The lines are too short to go anywhere else.Just replace and protect as necessary.Easy.
Old 08-06-2009, 12:42 PM
jjbaker1 jjbaker1 is offline
i rung gaffer tape round the lines where they can be damaged just for bit of protection
When the gasser runs right i am a very happy man, most of my life is spent being miserable!
Old 08-06-2009, 12:44 PM
mountain thumper's Avatar
mountain thumper mountain thumper is offline
try some wiring harness wrap, its cheap, and pretty tough, it can even be purchased in plastic and metal incarnations!
Le Crutan
98 ec250 sixdays, doma, eline pipe guard, zokes shivers from a cr250,fredette racing chain slider, protaper withbarkbusters (SOLD)
FOR THE SECOND TIME 07 EC300 polisport headlight, acerbis taillight ltr pv cover and case saver,trailtech endurance,120z fww, g2 throttle,xr chain puck:
Old 08-29-2009, 11:36 AM
Woodsrat Woodsrat is offline
I used a round file and filed a small gap in the plastic radiator shroud to clear the fuel line.
Old 08-29-2009, 08:23 PM
lukemillar's Avatar
I just used a couple of hose clamps and a piece of rubber tubes over the area. Still need new lines though
Old 09-09-2009, 04:57 PM
Devondan Devondan is offline
Originally Posted by lukemillar View Post
Here is a new one:
Thanks
Luke
Common problem it seems, I have the same issue but a bit of fuel line is easy to replace!
Dan
check your vent lines... stainlesscycle Enduro Chassis & Body 1 05-18-2010 03:54 AM
Leaking fuel lines. Metalefty Enduro Engine 4 stroke (including EFI & Exhaust) 5 10-28-2009 09:50 PM
A peek inside my '05 DE250 AZRickD Enduro Engine - 2 stroke 44 10-08-2009 08:51 PM
Triple Clamps clearance- Does this looks right?! PIX INSIDE alexpp General Discussions & Announcements 8 04-15-2009 09:14 PM
power valve vent lines skid jackson Enduro Engine - 2 stroke 2 06-16-2008 06:15 PM
