I installed a Recluse 3.0 on my 200 six days 2011it shakes and shutters?
So I am getting my new 200 ready to ride and one of the things I did was install a new recluse 3.0 but it shakes and shutters as I take off ? The bike also seems to stall ? I turned in the idle screw in but it did not seem to make a difference ? Any help would be appreciated I am planning on going to Hatfield n McCoy next Tuesday .
IF I HAD ALL THE MONEY I SPENT ON DIRT BIKES , I WOULD SPEND IT ON DIRT BIKES |
Mine will make some noise if I'm in a tight section and I'm one or two gears too high. Everyone has told me thats normal if you ride in too high a gear. I don't have any noise at all starting from a dead stop.
2011 GG EC 300E, 1994 CR 250R, 1984 RM 250 E, 2022 Ranger 300 "If you stop eating donuts you will live 3 years longer. It's just 3 more years that you want a donut." ―Comedian Lewis Black "I think best when I have a wrench in my hands." Soichiro Honda "Dreams are messages from the deep." -Unknown Sardaukar |
Go back and read the instructions. Twice. Too many plates? Do you have the adjustable slave?
2011 EC300 Six Days 2010 EC300 Nambotin Replica |
I'd pull it completely out and start over double-checking each step as you go. You have to be missing a part or have too many/not enough plates or they're out of order. Some of the kits have you reuse parts from your stock clutch and often shims will stick to the throwouts and you can miss swapping them over. After it's all said and done, check your free play gain and make sure that you have bled your clutch well if your kit has the adjustable slave.
Also, my GG 200 needed an extra shim in the clutch to make it operate properly but my 300 didn't. There doesn't seem to be any rhyme or reason to whether you need that shim or not other than if you have it all in there absolutely correct and it's out of adjustment clicks. |
Just an idea, check your free play gain, here is the Rekluse video on checking that measurement,
http://www.youtube.com/watch?v=Kv-W1Nsye9M
Thanks for the input guys I fixed it but am not sure what I did ? I changed the oil it was 90 weight put 75 weight in it took it out and it works ? It seems to be running great not sure what happened
The rekluse doesn't like thick oil. They recommend she'll Rotella t for all their clutches
I've had a couple of version 3.0 where the wedges did not throw at the same time. If you look closely at the wedges you'll see they're slightly grooved and it takes an hour or so for them to fully wear into the Teflon buttons.
From your description this is exactly what happened.
04 Montesa 315R, 07 EC300, 21 KTM Erzberg 300, 21 Sherco 300 SEF-F, 23 KTM 690, 23 Rieju Mr Pro 300 |
NEW recluse clutch ? | ACR Tom | Riding Techniques & Training | 5 | 02-23-2013 01:45 PM |
I wonder about the $400 Recluse exp for Honda working in a Gasser? | tnttimber | Enduro Engine - 2 stroke | 7 | 07-15-2012 09:36 AM |
Hand Guards installed | skraMnoR | Enduro Chassis & Body | 5 | 04-30-2012 07:11 AM |
new seat cover installed | boostedte37 | Pictures & Videos | 2 | 02-27-2010 01:03 PM |
