1999 200 triple clamp question..
got a bud who bought a 99 ec200.. the triple clamp looks really wierd.
it has gg stamped in it, but there is a boss where the bar clamps should go, and the upper triple has been drilled and a set of pro taper solid mounts are outside that boss to mount the bars.. also, there are no steering stops on either the upper or lower triple. it has the conventional marz forks.. anyone got a picture of what they should look like, or a spare set ?
broken down over 60 slow rider.. |
Someone drilled the extra holes to make the ProTapers work.
Can't remember if the fork tubes acted as the steering stops against the frame. |
he said the forks will actually get into the rads.. i was thinking the 00 i had had mounts and stops just like my 01, and those same forks..
Ok. It came back to me.
The head light strap around the fork tube acts as the steering stop against the frame. |
The 99 45mm Zoke 3xxx clamps DO NOT have steering stop screws. GasGas man is correct. I just checked my old clamps and there is NO stops. The headlight staps act as the stop.
As for the top clamp, only one handle bar clamp bolt hole, stamped "GG" into the top clamp. Do you want the clamps only? I'd like to move the entire front end.......let me know......PM me for a killer DEAL!
Rick 99 EC 200 06 RM 250 AMA D36 375X OTHG 375S ***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals |
i have sent this to him...
thanks guys
Thanks Jay.
Rick I sent you a PM |
Triple clamp ?? | rippn450 | Enduro Suspension | 22 | 04-18-2011 09:21 PM |
Ohlins Triple Clamp Question | thedeatons | Enduro Chassis & Body | 7 | 06-25-2010 05:52 AM |
Top triple clamp | pharrell | Enduro Chassis & Body | 10 | 01-16-2009 12:57 AM |
BRP top triple clamp | Link | General Discussions & Announcements | 1 | 11-08-2007 08:28 AM |
