Old 04-21-2017, 07:16 AM
Zman's Avatar
Zman Zman is offline
If you have a stock bike you probably have a large squish measurement and you will pick up low and mid range power with little loss in top end if you use a thinner base gasket. If you have any ridge at the top of the cylinder you do not want to use a thinner base stack than what was in there previously because of possible ring snag at TDC.
While the factor stacks gaskets with few issues, I prefer the single gasket over a stack. Another option is to use some spray tack to glue together multiple gaskets.
Old 04-21-2017, 12:32 PM
risk74 risk74 is offline
I've still never gotten a clear answer what that clear plastic "gasket" is for. I had never seen one before in other top end kits, I've never used it.
Is anybody running it?
Old 04-21-2017, 03:07 PM
Magellan Magellan is offline
Thanks. I think I'll go with the 1/32 gasket. I think it's close nough and I prefer one over multiple layers. No ridges to worry about, but I don't really have a need to alter the performance characteristics.
James
2004 EC300 -- LTR Stuff, RB Designs Carb Mod
2016 Africa Twin
1975 Honda CB400 F1 (X2, projects)
2019 RE 650INT
1982 KDX80
2017 KAW EX300
1982 XL500R
2015 HUSKY FE501S
1972 HON CB175
Old 04-30-2017, 03:33 PM
Zrt1200 Zrt1200 is offline
Typically if you have a plastic or aluminum shim It Needs a gasket on both sides to seal.
Old 05-01-2017, 06:20 AM
Do yourself a favour and see how the gaskets match up to the transfers, all of the ones I've had have overlapped into the transfers by about 3-4mm, not good for flow so cut them back!
2016 RM-Z450
Base gasket 2011 EC300 Quigs Enduro Engine - 2 stroke 10 10-04-2015 04:58 PM
wet base gasket thejackrabbit Enduro Engine - 2 stroke 6 02-09-2014 01:03 PM
Base Gasket re-use? motogroove Enduro Engine - 2 stroke 5 06-26-2011 07:56 PM
2010 300 Cylinder Base Gasket Question coopernicus Enduro Engine - 2 stroke 12 06-22-2011 09:31 PM
Base gasket Ud_luz Enduro Engine - 2 stroke 21 05-09-2008 07:38 AM
