Old 10-29-2016, 05:32 AM
sadiktm400 sadiktm400 is offline
Default shocking electric
hi.
my gasgas ec300 2t 2013 is shocking (electric)
I try to find a damage in the electric wire.
I find nothing
I cant ride the bike ,the problem goes worse when the rpm rise up.
please help
Old 10-29-2016, 01:13 PM
Neil E. Neil E. is offline
Never seen that before on a motorcycle. On antique cars with cloth covered ignition leads, sparks will jump around. Maybe replace your high tension lead and check that the coil is well grounded (clean the frame). A new spark plug might be a good idea if the internal resistor is failing.
Old 10-29-2016, 05:37 PM
I have experienced it.
But where are you getting the shocks delivered? When touching the frame?? My guess is the clutch/brake levers. In my experiences it has always been the front brake switch. Disconnect from the harness, or even better remove from the master and replace with a banjo bolt for better brake feel as well.
I've had this with my 2010 everytime I'd ride in the rain. Wet gloves, high rpm and then hard into the front brake to setup for a turn and getting zapped at the same time. Fun indeed. Mates 2015 Beta was doing the same as well. Disconnected and no reported re-occurrences.
Old 10-29-2016, 06:04 PM
pscook's Avatar
pscook pscook is offline
Another consideration is the kill switch. Check to make sure that it isn't grounding itself to the handlebars and then using your hands to complete the circuit. That might also cause some of your running issues as well.
Phil
(New bike pending...)
Old 10-30-2016, 01:41 AM
I've also had the same experience ... unwanted boost to the breaking in wet conditions is not ideal
Electric starter kit tonyraft Australia & New Zealand 7 10-23-2014 01:04 AM
Electric Starter Kit StuJohnson Parts 11 12-01-2013 09:43 AM
Shocking....just shocking! bukwheat General Discussions & Announcements 20 03-05-2012 02:14 PM
dogbone bearings shocking prices from gasgas uk so couple questions dirtjunky_uk Enduro Suspension 5 08-18-2011 02:24 PM
2011 300 six days handle bar shocking matt_tidball Enduro Electrical & Wiring 3 02-02-2011 09:36 PM
