#11
![]() Quote:
#12
got bearings tday, BUT, theres still a flipping bearing race stuck tried numerous things to get it out but, still not moving,
I HEATED UP WITH HOT AIR GUN BUT WAS NOT SURE HOW HOT TO GET IT, DIDN'T WANT TO FOOK IT UP, |
#13
So the inner races and balls blew out and you've still got an outer race stuck in there?
Those bearings musta really been shot... I assume you can't get a drift to bite on anything to drive the race out from the opposite side? Maybe get in there with a Dremel and grind some flats on the inside of the race so you've got something to hook your drift on? I don't think you can get it hot enough to "fook" it up with a hot air gun. The paint would bubble before you did any damage to the alu hub. Make sure you're applying heat to the hub, NOT the race. Try dosing it with some penetrating oil too.
Ross '05 MC 250 '91 Husky 610wxe '04 Duc M800 R.I.P '06 Duc S2r 1000 R.I.P '07 Duc S2r 1000 still rubber side down... ---------------------------------------------------------- May be so... May be not so... My Website |
#14
done now guys, thanks for all your advice, dremmelled it
Thread Tools | |
Display Modes | |
Rear Wheel Bearing 2001 XC250 | thomasbyrd | Enduro Chassis & Body | 0 | 10-04-2009 03:04 PM |
05 250 front wheel bearing seal #??? | Bandit9 | Enduro Chassis & Body | 3 | 10-29-2007 07:49 PM |
Rear wheel bearing ? | ktmguy23 | Enduro Chassis & Body | 1 | 03-22-2007 07:45 AM |
Front Axle/Wheel Removal | gasIdaho | Enduro Chassis & Body | 1 | 02-15-2007 09:31 PM |
Bearing Removal? | Boomhauer | Enduro Chassis & Body | 0 | 12-06-2006 09:20 AM |
