Old 01-17-2019, 12:18 PM
mrquick mrquick is offline
Originally Posted by taylor146 View Post
Hi Mr quick, can I ask what brand of gear oil you used?
Thanks
Hi I am using Castrol edge 5/30
Old 01-17-2019, 12:24 PM
Davehuge's Avatar
Davehuge Davehuge is offline
Originally Posted by mrquick View Post
Power valve noise on decents and when trundling along road sections, so I have striped the power valve out and found alot of sideways movement so I made a stainless shim, placed it on the water pump side of the barrel, I basically halved the play in the valve and boy what a difference its made its quiet as a mouse now...
A while back I had the same rattle on decents/overrun and found side to side play in the power valve, I too fixed it by adding a shim each side. Interesting you had the same issue on a new(ish) bike, I thought it was just because mine is a well used 2004 bike.
Old 01-17-2019, 01:15 PM
It seems like they all do it Dave, some people it doesn't bother them but me I hated it, the S3 head sorted alot of issues out because its lowers the compression ratio, the bike runs smoother, starts easier just genrally so much better than standard..... Mine has done about 47 hrs now
Old 01-17-2019, 01:42 PM
Davehuge's Avatar
Sounds great... although surely reducing compression ratio = less power?
Old 01-17-2019, 02:30 PM
Thanks for the update mrquick. What has the S3 head improved, I am thinking about getting one too and have the same bike. Is it stronger down low? is it easier to lug in a too high gear?
Cheers Doc
Old 01-17-2019, 02:57 PM
Yeah nah yeah!
Increasing compression ratio increases power up to a certain point.. Too much compression can result in you having to run richer than ideal to stop pinging. Higher octane fuels can help as well.
High comp ratios tend to be quite snappy and responsive off idle. Taking some out lets the engine feel smoother... which is not always a bad thing in a dirt bike where we often struggle to put power to the ground.
I prefer to set my engines up with a tight squish (improved efficiency and power across the rev range), while keeping the compression ratio reasonable (to allow use of average fuels without worrying about pinging).
Lots of aftermarket tuners/head designs bump impression because it's an easy way for the end user to feel a change through seat of the pants.
Old 07-24-2019, 01:48 AM
rodent's Avatar
rodent rodent is offline
Mrquick, who's pipe guard is that that(manufacturer part#)?
Mine came delivered with a guard(propower) and it's a very ugly fit(points in the wrong direction at the small end )and needs some rubber mallet encouragement to fit........sort of
Personally I believe it's the wrong one for my bike.
Edit.... After looking at the"Propower" website, they have a pic of the same poor fitting item I have..........Maybe it's time to buy someone else's
Old 07-24-2019, 02:42 AM
RudolfHucker's Avatar
RudolfHucker RudolfHucker is offline
It's a CMT guard. I have one for sale on eBay in the UK as I don't have my EC300 any more.
https://trialendurodirect.com/produc...59796142578125
Old 07-24-2019, 02:58 AM
rodent's Avatar
Thanks for the reply Rudolf
Could you shoot me a PM with a link to yours? Would you send to OZ? Will you pull from auction to sell?
Old 07-24-2019, 03:41 AM
gg3's Avatar
gg3 gg3 is offline
that is a hot looking bike!
2019 Gas Gas updates swazi_matt General Discussions & Announcements 150 10-29-2018 05:24 PM
2019 EC 300 first ride (euro model) Doc Brown Ride Reports 7 09-19-2018 01:17 PM
2019 gp CORSA General Discussions & Announcements 1 08-02-2018 06:37 AM
Poll 2019 KTM XCW 300 TPI 6 Days Moto7man Pictures & Videos 16 06-28-2018 03:43 PM
2019 KTM XCW 300 TPI 6 Days Moto7man Pictures & Videos 2 06-21-2018 03:20 PM
