Running blinkers with a Reg/Rec?
How do you run blinkers with a trailtech REG REC? I have a DC system that charges the battery. I made a working mockup and the flasher relay does work, just not when it's plugged into the loom. Lights and horn stop working as soon as it's added.
12v to relay, relay to switch, switch to blinkers. Blinkers ground back to battery. All the other lights ground at the battery as well. Thoughts? |
Just going to throw an edit in here, not that this will likely help anyone but here is how I solved it.
I ended up with 12v to switch, switch to lights, lights ground to the relay, relay grounds to battery. For whatever reason, this works. The brake light was giving me issues, and not sure why still, but it is also solved. Last edited by GGRider01; 07-10-2016 at 05:18 PM. |
Thread Tools | |
Display Modes | |
NEW rear blinkers from 2011 EC | nknudsen | Parts | 2 | 09-29-2014 09:20 AM |
2012 ec250e blinkers?? | Novascotiarider | Enduro Electrical & Wiring | 5 | 01-24-2013 01:42 AM |
06-300 not running | davedunaway | Enduro Electrical & Wiring | 11 | 08-29-2012 09:21 AM |
03 300 not running | tophat | General Discussions & Announcements | 22 | 08-23-2011 03:51 AM |
Running In | Dingo | Enduro Engine - 2 stroke | 3 | 07-26-2007 11:36 PM |
