Old 01-18-2012, 04:25 PM
krazy's Avatar
krazy krazy is offline
Default transmission drain plug shavings
Hi,
Just pulled my drain plug and it seems to have lots of shavings, see pic. Is this a normal amount of clutch/gear crud?
Thanks
Krazy
Old 01-18-2012, 04:39 PM
ucrtwf ucrtwf is offline
Is the bike new? How long between oil changes? Rub the "shavings" between your fingers. Are they smaller particles stuck together with the magnet, or large ones?
If they were small, and you don't change the oil every ride, I wouldn't worry too much.
2010 EC300
2003 YZ450F
2006 SSR125
2005 Z1000R
1997 GL1500
Old 01-18-2012, 06:35 PM
Agreed. I generally have a few fine particles that come out with every oil change. More so the first few rides, or if you abuse the clutch heavily and don't change the oil.
PV left drain plug gasgasquebec Enduro Engine - 2 stroke 8 03-20-2010 06:09 PM
2T drain plug wence Enduro Engine - 2 stroke 0 10-13-2009 04:28 AM
oil drain plug nitroman Enduro Engine 4 stroke (including EFI & Exhaust) 1 08-18-2009 07:32 AM
Oil Drain Plug size Motarded1 Enduro Engine 4 stroke (including EFI & Exhaust) 1 06-22-2008 12:08 PM
Oil Drain Plug MIKEWA Enduro Engine - 2 stroke 4 01-27-2007 06:19 AM
