Old 05-04-2017, 10:38 AM
Nicke_pota Nicke_pota is offline
Default GasGas 125SM 04 Small end bearing
I've been looking everywhere for a top end bearing that will fit my piston rod and piston pin, the problem is that in the manual, it says that the bearing should be 18x22x22 but when I tried that one, it didn't fit the pin. It might have another piston kit, but I'm not sure. Does anybody know about popular piston kits for the 04 125? And if so, what type of top end bearing will fit. BTW The piston that was already in it when it broke was a w?ssner piston if that helps.
Old 05-04-2017, 12:10 PM
the 2005 engine parts manual shows the bearing dimensions you mentioned which I agree is not correct. I believe the 125 pins is 15mm not 18mm like the 200, 250 and 300.
http://www.ebay.com/itm/Cage-a-aigui...RYdIM1&vxp=mtr
http://www.wiseco.com/ProductDetail....04&AppID=26795
Some years 125 had a flat top piston and some had a dome. The GG125 pistons interchange some YZ125 and CR125 pistons but you need to match what is in the engine (provided the correct piston is already there).
Tags
125sm 04, needle bearing
Small amount of oil in crankcase memphis2857 Enduro Engine - 2 stroke 8 09-30-2014 10:41 PM
GasGas small fit vs others true? Sizing changes over the years? RonC General Discussions & Announcements 34 04-19-2013 09:27 AM
GG ec300 - too small Richard General Discussions & Announcements 15 02-24-2011 07:57 PM
Small changes I would like to see. REVERUP General Discussions & Announcements 92 01-04-2011 04:23 PM
Small bike and ATV ban. Ud_luz General Discussions & Announcements 22 05-04-2009 01:06 PM
