#371
05 GG EC 300 Rekluse Smart Carb SSS Front & Ohlins Rear by MPE FMF Gnarley & Powercore 2 2013 (4t) Racing update Kit |
#372
read thru this thread it is in here on a page about the air filter spring with a picture.
#373
Take a look here, these are the parts to make the airfilter device work. http://partsfinder.onlinemicrofiche....20AIR%20FILTER Still looking into the airboot hitting the rear shock. I don't think it's critical, but it does touch and pushes the plastic bit that snaps onto the frame off of the frame a bit, which will probably cause some headache while installing the seat which snaps over/under that plastic, further pushing the boot into the shock. Also, the front fender I received only had two holes that lined up with the holes on the bottom of the triple clamp. I ended up just drilling 2 holes where the front two bolts go through the fender. If I don't figure out what that crazy little device bolted to the top of the fender is for, I'll drill two holes into the front of my triple and run some bolts through the front of it. Talk about over kill! One last question, how are you securing your ECU(?) box? I ran all the wires along the right side of the frame (they were on the left side factory) and through the hole in the airbox and now the ECU is just kinda hanging out in there unsecured. Last edited by GGRider01; 08-16-2015 at 10:21 PM. |
#374
The front fender mounts differently on the later models. Drill and tap two holes in the front of the lower triple and mount the fender support to it then bolt up the front fender. Two in the back in the triple underneath two in the front on the support bracket. Not really overkill just a different way to mount it. As for the ECU find a way to mount it to the inside of the airbox. Later models have a bracket for it. the older models that have the conversion, you need to make something up for it. be creative or just zip tie it to the inside of the frame in the airbox? |
#375
I only meant it would be overkill because I'll have a total of 6 bolts holding it on if I drill the lower triple, which is more than any other piece of plastic on the entire bike.
As for the airboot hitting the shock, I'm afraid I'm going to have to unbolt it and rotate it significantly away from the shock. It lines up with the carb very nicely where it's at so I'm considering just melting it. Ok, screw everything I said about that filter retention device. It's really simple. Here's a picture of the device in action. Sorry for the dirt, I do all my work outside Last edited by GGRider01; 08-18-2015 at 12:26 AM. |
#376
Older bike
Over here where it's legal to ride on road the older ones fit in mine attached 2000.
#377
Parney, that is exactly how my bike looked before I tore into it. It was in pretty sad shape though. I was bummed when I couldn't find that exact seat cover, so opted for the upgrade kit instead of going original.
#379
[QUOTE=Ok, screw everything I said about that filter retention device. It's really simple. If your plastic wireframe that goes inside the airfilter has prongs sticking out of it, cut them off if they don't have corresponding holes in the airbox. I just reused the one I already had. I don't like the new one that came in the kit. Here's a picture of the device in action. Sorry for the dirt, I do all my work outside [/QUOTE]
Thanks for the photo of the air box retention device, more than a little embarassed I didn't figure that out. Thanks for the input DG300 Going to get a new air boot and front to the air box and re do it, mine is way butchered compared to yours GGRider01
05 GG EC 300 Rekluse Smart Carb SSS Front & Ohlins Rear by MPE FMF Gnarley & Powercore 2 2013 (4t) Racing update Kit Last edited by BigAl; 08-17-2015 at 09:20 PM. Reason: wrong quote |
#380
I had a real bastard of a time to be honest. It looks like I've been playing Patty Cake with Edward Scissorhands.
I ended up riveting the front airbox plate to the rear, larger portion of the airbox before sliding it onto the subframe. I placed 3/16 inch rivets through the little tabs that overlap the rear section. Then attached the subframe to the bike as one whole unit, rear fender and all. I had to wrestle every last piece into place every step of the way. I am going to ride this bike until it turns into a pile of dust before I ever strip it down to pieces again. |
Will the newer model plastic fit older bikes? | juice76 | General Discussions & Announcements | 9 | 10-14-2020 03:44 PM |
new body work on older bike? | knobbyboy | Enduro Chassis & Body | 18 | 01-12-2011 05:40 PM |
Older GasGas Questions | nick2510 | General Discussions & Announcements | 10 | 12-16-2010 07:03 PM |
Vancouver Bike Show | HuskyDude | General Discussions & Announcements | 8 | 01-26-2010 10:14 PM |
