Old 01-09-2019, 12:28 PM
Wypipo Wypipo is offline
Default Fork height in triple clamps
Does anybody know what the factory height above the top triple clamp is? I took mine out but forgot to measure first
Old 01-09-2019, 03:38 PM
There are recessed lines in the top of the outer fork tubes. Factory height would be with the top line in the fork tube at the top of the triple clamp.
Old 01-10-2019, 11:35 PM
shawbagga's Avatar
Most are on second line from top(5mm) here in Aus. Run mine third line down(10mm).
'18 Gasgas XC250
Old 01-29-2019, 03:49 PM
Saddleback51 Saddleback51 is offline
It really is what feels best to you. The more you raise the forks, the faster it will turn buy you lose straight line stability.
Old 01-29-2019, 06:47 PM
It depends on many different things like your riding body placement, spring rate, preload and relationship between front and rear suspension. You can use the fork tube height in the triple clamp to fine tune your setup.
Triple Clamps, Fork Guards, Front Axle RockefellerGG Parts 7 02-17-2017 04:21 PM
triple clamps dublin "Wanted to Buy" & "Want To Trade" 2 07-25-2013 08:18 AM
triple clamps gassergrant Enduro Chassis & Body 2 10-02-2012 04:23 AM
triple clamps hallyfromspen Enduro Chassis & Body 6 02-25-2012 09:25 AM
Outer diameter of Sachs fork at the triple clamps Leon_gasgas Enduro Chassis & Body 3 01-20-2010 06:21 PM
