Old 12-26-2016, 02:12 PM
EC_CC_Rider_300 EC_CC_Rider_300 is offline
Default 2014 XC300 R Stator wattage
Hi all I am trying to figgure out the stator output of my 14' XC300R Kick start only.
The manuals on the GG motos site dont give stator output that I have found.
Thank for any help.
Old 12-26-2016, 05:30 PM
Neil E. Neil E. is offline
If you assume the 2K3 delivers 70W and set your loads up based on that figure, you will be fine. TrailTech lists a 100W stator if you need maximum output.
2011 EC250E
Old 12-26-2016, 08:57 PM
Zman's Avatar
Zman Zman is offline
If it is a 2k2 it is only 35W but you can make 35W go a long way with LED bulbs.
Old 12-26-2016, 11:26 PM
Anders's Avatar
Anders Anders is offline
Thank for any help.
According to the Norwegian importer, my 15 model will handle a constant load of 65w. I presume the 14 has the same electrics.
Sent fra min E5603 via Tapatalk
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 12-27-2016, 03:53 PM
Thanks for the replies, I have a 36w Cyclops LED drop in bulb in the stock headlight housing.
Its rated at 3600 lumens and works well. I also am running grip heaters and am curious if I can run another 18w LED light bar. Probably maxed out as It is though.
Old 12-28-2016, 01:20 AM
Anders's Avatar
Your grip heaters is probably in the 25 to 35 w range, so Yes I guess that is what you can expect it to drive. But you could wire the led bar and the heaters to a switch so that only one of them are powered. If you need heat, you turn off the extra light. If you dont need heat, you have max light.
Anders
1986 Duc Mille S2
etc
EC 300 Racing 2014 Stator problems erikkihl Enduro Electrical & Wiring 4 01-04-2016 06:21 PM
2014 xc300 earlystock Enduro Electrical & Wiring 10 03-13-2015 03:14 PM
2013 or 2014 xc300? earlystock General Discussions & Announcements 21 04-19-2014 02:36 AM
2014 XC300-e just arrived!! rosco New Bikes 25 01-12-2014 05:26 PM
ec300 stator on xc300? Jeremyxc300 Enduro Electrical & Wiring 3 05-22-2013 08:06 PM
