Old 01-27-2013, 04:38 PM
iamyvr's Avatar
iamyvr iamyvr is offline
Default WP43's HELP, can't get the Compression holder out!
So Today was to be the day to rebuild the forks... Bushings, seals, etc... check.
Follow the manual, check....
Lower compression holder,.... all jacked up. It appears that some monkey had cranked these in way too tight, and now they will not come out. Of course I have damaged the 19mm nuts as well.
Is there any special trick to get the compression holders out? I am sure I will need to replace them when the are removed, but for now I just need them out.
I have found a set of WP43's from a 2002 KTM 250EXC for a good price, but are the axle clamps the same? Will I have more trouble getting these to work, or will they just bolt up to the wheel and caliper?
Old 01-27-2013, 06:54 PM
pscook's Avatar
pscook pscook is offline
The KTM lowers are different. Axle size is right, but the right side end (internal hex) is 1mm smaller OD if I remember right. The other issue is the brake caliper mount as the KTM has thicker lugs on the rotor side which pushes the caliper into the rotor. You can machine those down 1 or 2 mm to make up the difference and spin the axle smaller and they should fit right up. I have a set of KTM 43's downstairs for parts on my 2002 and found this out when trying to mount them up. Not a direct bolt up, but the issues can be overcome if you know of them in advance.
Phil
(New bike pending...)
Old 01-27-2013, 07:02 PM
iamyvr's Avatar
thanks Phil,
I am hoping to take a fresh crack at them tomorrow (with a fresh attitude) I am still hoping to get them out...
but if not, I have a place to start...
Old 01-27-2013, 08:52 PM
pscook's Avatar
thanks Phil,
An option is to buy the KTM WP's and swap the bottom brackets. It depends on what gets damaged during disassembly. I bought my KTM 43's for the exact reason to have spares as my GG WP on the right side has a seized compression valve (seized to the lower) and the right rebound clicker was inoperative. I plan to mix and match in the spring when my schedule frees back up.
Phil
Old 01-28-2013, 08:34 AM
jhendr3702's Avatar
jhendr3702 jhendr3702 is offline
i have a set of gg 43 wps if you need any parts..
broken down over 60 slow rider..
How can you tell when it is time to replace your WP43 fork Bushings Zman Enduro Suspension 4 01-15-2013 09:16 AM
Cdi holder Rabbitist General Discussions & Announcements 5 10-05-2011 09:05 AM
Lower rear suspension-also tailight holder mattmax General Discussions & Announcements 2 11-11-2006 08:51 AM
