Old 01-31-2013, 10:58 AM
Scar13 Scar13 is offline
Default Flywheel weight on a 2010 ec250?
So I was looking to add some fly wheel weight to my 2010 ec 250 and was told it allready has the heaviest fly wheel possible?? I was told to look at the position of the wire coming out of the bike and if its in the 10 o clock its the lowest one , but if the wire is in the 2 o clock position I am at the heaviest?
Thoughts??
Old 01-31-2013, 11:52 AM
Yes, you have the heavy 2K-3
Sent from my C771 using Tapatalk 2
Old 01-31-2013, 12:40 PM
Thanks Gmp!! I assume then none of the stealthy weights are heavier .. Maybe rekluse time
Old 01-31-2013, 12:47 PM
There is a lot more inertia in the 2K-3 than in a 2K-2 with the heaviest weight. I suggest trying a G2 throttle with a #200 cam and/or some jetting work if you feel its not smooth enough. Eventually you may even want less weight.
Old 01-31-2013, 02:28 PM
djroggen's Avatar
djroggen djroggen is offline
2T Racing Flywheel for the Large 2k3 ignition
I have one on my bike and I love it.
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Ortonville Minnesota
Old 01-31-2013, 05:51 PM
As above.
You can get a heavier flywheel weight for the 2K3 if you want to. There is nothing or no one to say whats right or wrong.
Typically though, people who are adding weight are running the lighter 2K2 ignition and flywheel which as Glenn has said has less inertia even when decked out with a heavy weight. I've got a 2K3 and want less weight, but its all personal preference.
What are you trying to achieve? What have you already tried?
Old 02-01-2013, 10:28 AM
first thank you everyone for your replys, part of owning a GG is this forum and the helpful and polite people!!
I will give the G2 a try after reading about it!! My biggest issue is I am racing woods and there is TONS of sand which I have to stop due to other riders ( ME FALLING!!! ) Wet rock/ Muddy areas and I am finding I am spining the rear tire to often on those but importantly the rocky Climbs..
Old 08-31-2015, 03:34 PM
dalbertog dalbertog is offline
Hey, I know its been a while, but i'm in the same position as you and am looking into additional flywheel weight. Which one did you ultimately go with, and how did it work out?
Old 09-05-2015, 10:49 AM
farmerj's Avatar
farmerj farmerj is offline
I used the S3 and think it's great.
http://www.gasgasrider.org/forum/sho...heel+weight+sx
But as GMP has alluded, others will not like it and want less weight, not more! If you're a racer and want hit, this is not for you!
But for torquing up nasty hills and such without stalling, I find it works well.
Jeff
'18 GG XC 300
'05 GG DE 300
'01 GG txt 321
2010 300 flywheel weight choices forgiven Enduro Engine - 2 stroke 5 04-27-2011 07:57 AM
Help! Flywheel weight doesn't fit with 2k3 on 2003 EC250? SideshowBob Enduro Engine - 2 stroke 12 04-28-2010 11:02 PM
