Old 10-22-2018, 05:11 PM
Chris_tian Chris_tian is offline
Default Piston /power valve GP2018
Hello.
Does one already have problems with the piston ??
Have heard that the original piston should break quickly ??
My kickstarter is very light last week. I have to kick first to get compression and then only half of the way.
My GP has only 30 hours or is it normal with the Kickstarter?
Can you damage the power valve by over tightening? I had put on these too strong and it turned something in the engine but when I look at the drawing can not happen because you turn the crankshaf something.
Greeting
Old 10-23-2018, 02:03 AM
Anders Anders is offline
Originally Posted by Chris_tian View Post
Hello.
I have no experience with the 18 GP, but the OEM piston in older bikes had good quality. 30 hours should normally be no problem. I replaced my OEM 200cc piston after 100 hours and it still looked OK. Now, my bike is close to 200 hours and a new piston will be put in during the winter service.
OTOH, if you feel significantly less compression after only 30 hours, I would take a look inside to check. These engines are easy to work on.
Old 10-23-2018, 05:08 AM
eralha eralha is offline
Hello.
Greeting
Mine is almost 60h and looking good on compression department, i took out the exhaust and took a look trough the cylinder hole, the piston looked good to go. so i will just change it at about 120h if it dont lose compression until there.
Old 10-24-2018, 01:48 PM
Hello,
i don?t know.... but i try it again and i have good compression. Sorry i thinking too much
So i keep on riding.
Ec 300 power valve Jonisaacson17 Enduro Engine - 2 stroke 11 07-18-2016 09:01 PM
Blown piston, Power valve Tommy Enduro Engine - 2 stroke 2 05-24-2016 09:46 AM
Loss of power - suspect power valve Jonny Halls Enduro Engine - 2 stroke 4 01-22-2013 09:56 AM
power valve nut bonkeye Enduro Engine - 2 stroke 4 10-11-2012 06:40 PM
Power valve bens25au Enduro Engine - 2 stroke 2 02-09-2008 11:02 PM
