Old 10-15-2018, 01:07 PM
Kpo73188 Kpo73188 is offline
Default 2007 ec250 powervalve question
Hi I just picked up a 2007 ec250, I noticed a rattle when the rpms are coming down. I read about adjusting the powervalve. when I pulled the pipe off the bike I noticed the powervalve was covered in carbon and I'm able to wiggle the valve back and forth in the cylinder, about an 1/8in either way. Is the normal or is there something that can be tightened or replaced, thanks
Old 10-16-2018, 05:12 PM
Davehuge's Avatar
Davehuge Davehuge is offline
HI, I have a 2004 EC300. When I first got it I had the same rattle that you describe.
When I removed the exhaust and stuck my finger up the exhaust port I could move the power valve from left to right quite a lot and replicate the same rattle.
I removed the power valve bearing and installed a shim (well just a washer really) to limit the side to side movement but not eliminate it completely, I didn't want to risk it binding.
This reduced the nasty rattle but not completely. A few weeks later I removed the cylinder head/barrel and found the piston and rings were badly worn, really badly worn, the piston rings end gap was 2.0mm! After replacing the piston kit I then had a really quiet motor with no nasty rattles and loads of compression!
So my advice would be to try shimming the power valve, if you still have a rattle pull off the head/cylinder and check the piston and rings.
Old 10-16-2018, 07:06 PM
(F5)'s Avatar
(F5) (F5) is online now
1. Put your foot in the chamber front when you rev it. Add more Springs and new manifold ORings if so. Plus other 2 mounts.
2. So you adjusted out the slop of the lever? Mine was rubbing the wire against the wall of the tube and the lower lever was hitting the case when in bottom position.
The valve will move around a bit and helps keep it from seizing. You can and should pop it out occasionally and remove the carbon . There's instructions on the main site. It's easy when you work out 1. Melt the nyloc screw then replace. 2. After making a special screw in puller I read and realised that you can just push stuff out from the other side. Doh.
Retained the tool in valiant defiance that it might get used for something.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Thread Tools
Display Modes
2007 EC300 Showa Conversion - Triples Question ssaulnier Enduro Suspension 5 01-21-2018 11:01 AM
2007 to 2011 frame question CanGasser Enduro Chassis & Body 5 09-23-2016 04:44 PM
Powervalve bearings question SS109 Enduro Engine - 2 stroke 10 12-07-2014 11:56 PM
New 2010 EC300 - NOOB Powervalve Vent Question JP4 Enduro Engine - 2 stroke 2 11-29-2010 07:48 PM
2007 owners - side panel question Shiny Enduro Chassis & Body 2 10-29-2007 01:26 PM
