Old 12-17-2013, 04:48 PM
Lincolnlock Lincolnlock is offline
Default 2001 XC200 Restoration Project
So I decided I needed a new project. And why not start with a $400 2001 xc200? The bike needs a ton of work obviously. It didn't start when I bought it, but a couple of new carb jets and it started right up. The bike sounded ok, but after a couple of minute of running the engine shut off and the kick start was really hard to push down. Turns out the lower connecting rod bearing was starting to lock up. Oh well... So I'll post updates as I go. I still need a few more items to put the engine back together. It should be a fun winter project anyway.
Old 12-17-2013, 05:08 PM
bowhunter007's Avatar
I've never ridden a 200cc GG. Should be a fun bike...especially at Walker.
Old 12-17-2013, 05:24 PM
Just did the same thing for my son's 200. While you are in there you may want to consider replacing the other bearings in the trans.
I believe these are the correct transmission bearings but double check against what is in your trans.
Bearing #
Counter shaft bearing 6305C3
Countershaft Seal 30x40x7
Clutch bearing 6205Zc3E
Trans shafts 6203c3
98-02 Crank 63/28c3
Old 12-17-2013, 05:45 PM
pscook's Avatar
pscook pscook is offline
Great find! Good thing you found it first.
Quick tips- Crank nut on the water pump side is reverse thread. YZ Flywheel puller is a perfect fit. And Bob Piper at North Tahoe Motorsports will hook you up for all of your hard parts and any tech data you need. Good prices, fast shipping, and good guy. Here's a link to one of his ebay ads- http://www.ebay.com/itm/TOP-END-WOSS...45baf2&vxp=mtr
Drop him a note to see if he has 200 stuff, I would think he should.
Also, the only thing different from the 200 to the 250/300 is machining of the cases, crank, and top end (including jug). The chassis are the same, if you didn't know this already.
Phil
(New bike pending...)
Old 12-17-2013, 06:51 PM
Phil - Are you sure about the crank nut being left hand thread? I did a 2002 and a 2004 EC200 recently and I could swear the clutch side crank nut was a traditional right hand thread.
Old 12-17-2013, 09:13 PM
pscook's Avatar
On my 2002 300 it was reverse thread. Lefty tighty and righty loosey. Of course, an initial inspection of the lead-in threads will tell the story, but I am certain that the primary nut is reverse.
Phil
Old 01-17-2014, 04:38 PM
Well... I got the crank rebuilt with a cr250 rod kit. Then I ordered a truck load of parts. I put the crank bearings in and bolted the cases together. The transmission would only spin a 359 degrees and then lock up solid. So I figured out why the bike was parked. The secondary pinion has a tooth that is about to fall off. So I still need to source another one of those. Other than that gear, the bike would be running again. Oh well. Let me know if there is a used gear I could purchase. This bike project is running over budget.
Old 01-17-2014, 06:40 PM
You will not be able to ride it very far that way. That is a bummer.
Old 01-18-2014, 12:20 PM
PEB PEB is offline
Sam which gear is the secondary pinion?
Old 01-23-2014, 02:29 PM
Well, no one in the world seems to have one of these gears. If anyone know of one, please let me know. It is part number: ME25636076
2002 GasGas xc200 gasser Used Bikes 5 08-05-2013 09:25 AM
Fl Harescramble 2012 GG xc200 Jetster220 Pictures & Videos 24 05-16-2013 08:25 AM
Trail riding on '12 XC200 Jetster220 Pictures & Videos 0 04-21-2013 12:52 PM
Plastics for '04 XC200 Bulgas Enduro Chassis & Body 2 04-03-2013 07:20 PM
Project: 2001 XC300 bare frame rebuild motogroove General Discussions & Announcements 64 06-16-2011 05:56 AM
