Old 09-07-2009, 05:08 PM
stevethebrit's Avatar
stevethebrit stevethebrit is offline
Default Loose yellow wire in airbox
Hey guys! I found a loose yellow wire when I was doing my filter change on my EC300 2008 (first owner). I remembered seeing it before, but never got around to checking what it is for. I've looked at the wiring diagram, but I'm not really an electrics guy, which also explains my reluctance to rip everything apart to try to find out where it goes. The bike works great, and all the road kit too (turn signals and horn are not on the bike now in woods mode, but worked when they were on). The only thing that doesn't work (not so I can tell) is the rain/sun switch. Does this cable have something to do with it? Can't find an empty connector either, otherwise it would be a no-brainer. Would be great if someone could enlighten me!
/Steve
EC 300 2008
Old 09-29-2009, 05:59 PM
rossrc rossrc is offline
Hi Steve,
You've probably moved on, but I've been told it's for the tacho
BTW Your pic helped me put my connectors back together... so thanks!
Ross
Old 09-30-2009, 04:40 PM
Glad I could help! My tacho is connected with a Trailtech cable after delivery. I'll leave that yellow wire dangling, is good to know that it's supposed to be there anyway.........
EC 300 2008
Loose Airscrew biggstr6 Enduro Intake/Carburetion - 2 stroke 6 07-29-2010 09:07 AM
loose bottom marzocchi cap noobi Enduro Suspension 2 06-06-2010 07:48 PM
Blue/Yellow wire disconnect, must you now retrim?? GavGav Enduro Engine 4 stroke (including EFI & Exhaust) 11 09-02-2009 05:25 AM
Airbox Removal gasIdaho Enduro Chassis & Body 2 02-13-2009 12:37 PM
blue and yellow wire dukbil Enduro Engine 4 stroke (including EFI & Exhaust) 1 03-16-2007 09:54 AM
