#21
this was a regular discussion around 2010/11
No definite fix some successes were to use different oil (belray gear saver was a huge improvement for me), others drilled holes and what appeared to be the most effective was removing all the unnecessary friction material on the friction disks (ie so you are left with tabs of friction material and then bare metal inbetween. I tried to do this and after sorting out ONE tab i decided i could live with the squeal!!)
Clutch washers like Beta guys use to make light clutch feel | Dingo_ed | Enduro Engine - 2 stroke | 3 | 11-19-2018 03:15 PM |
Auto clutch Install, Rekluse or S3 Clutch Basket? | Moto7man | General Discussions & Announcements | 49 | 11-24-2013 12:41 AM |
Clutch lever doesnt release clutch as soon as motor starts | cal_tony | Enduro Engine 4 stroke (including EFI & Exhaust) | 5 | 05-19-2012 08:59 AM |
front brake howl | ec300 2t | Enduro Chassis & Body | 4 | 02-12-2007 07:33 AM |
