Go Back   Rieju & GasGas Legacy Riders Club Forum > Classified Advertisements > Parts
Parts New/Used Components and All Bike Part Outs
Old 02-20-2020, 08:25 AM
TheTrojan TheTrojan is offline
Default Needed - 2013 EC 300 Clutch Slave Cylinder
Hi All
I am desperate for help! I'm trying to find a new or second hand clutch slave cylinder for me EC 300. The part number is ME25632026 and by the looks of the workshop manuals was the same part from 1996 to 2014.
My chain broke and tore up the casing. Now the fluid is just bypassing the seals.
Please can anyone help with contacts, even overseas, that I can try order from.
Thanks a million!!
Old 02-20-2020, 12:52 PM
blitz11's Avatar
blitz11 blitz11 is offline
In my quest to keep my 2002 running as long as possible, i spent time with the parts fiche.
You can still buy a slave cyclinder for US$105 from Gasgas. I think that the slave cylinders from 2015 onward, although not AJP, will also work with your bike.
The number of changes GG made to the engines of these bikes from 2002 - today is quite small. I was worried about parts availability, but "new" things should fit older bikes.
Old 02-20-2020, 03:06 PM
Anders Anders is online now
You could also use a Rekluse slave, I believe.
Old 02-20-2020, 03:47 PM
risk74 risk74 is offline
PM sent. I have a slave cylinder in good working order from a 2011.
Is it possible to convert clutch slave cylinder to dot4? jan_b Enduro Engine - 2 stroke 7 12-19-2014 12:01 PM
Will a KTM clutch hose fit the banjo bolt on my GG slave cylinder? bondo Enduro Chassis & Body 7 12-11-2014 12:53 PM
2010 250f clutch slave needed CACTUSREID Enduro Engine 4 stroke (including EFI & Exhaust) 0 01-30-2014 08:34 AM
clutch slave cylinder hydraulic seal Boodog Enduro Engine - 2 stroke 3 07-08-2013 05:45 PM
Clutch Slave Cylinder Rebuild newgaser Enduro Engine - 2 stroke 5 03-17-2012 08:30 AM
