Old 11-26-2021, 12:25 PM
Jcvd30 Jcvd30 is offline
Default Fuel Tank HOLE Gas Gas EC 250(300) 1999 HELP
hi guys ,
so went for a ride on sunday and fall down with left side of the bike. today when i fill the tank in the end gasoline start dropping for the screw hole. the screw wasnt there so with the drope make a hole on fuel tank.
do you think is possible to put some epoxy glue ? and after a new screw...
my doubt is if gona seal good because of gasoline
what you think?
sorry my english
Old 11-26-2021, 12:31 PM
Default fuel drop
image where the hole is and fuel drop
Old 11-26-2021, 02:04 PM
JAD JAD is offline
You can buy some repair paste/filler/adhesive specifically for fuel tanks. In the UK one option is "Petro Patch". I have used it successfully on metal fuel tanks.
I would not be too confident about replacing a screw in the same place though... Maybe build up plenty of repair paste and use a shorter screw?
Maybe something like this... https://www.repairingproducts.co.uk/...nk-repair-kit/
Retired
EC 250 (2007)
UK
Old 11-27-2021, 09:07 AM
yes , i buy epoxy glute that is resistant to gasoline. lets see if it works
Old 11-27-2021, 06:53 PM
You need something that will stick to the tank plastic. I would also rough it up a bit with Dremel tool or knife to give the glue a better chance of sticking.
There is one on ebay for $90.
https://www.ebay.com/itm/11510861704...wAAOSwoNJhnUXM
Old 11-28-2021, 09:52 AM
ok thanks. i let it dry and put some fuel on the tank and dont come out. i think epoxy glute covered the hole.
tomorrow go for a little ride to make the final test.
IMS GG#1 Tank fits EC250s 1997 to 1999 gregorythomas Parts 3 11-04-2013 08:56 AM
Plastic ec 250 tank hole Rabbitist General Discussions & Announcements 7 08-24-2011 01:23 PM
05 tank and seat onto a 1999 ec? jonny Enduro Chassis & Body 4 01-23-2008 09:09 AM
FAQ Input: Repair gas tank mounting hole at front of frame MattR Enduro Chassis & Body 9 12-07-2006 07:08 PM
