Enduro Engine 4 stroke (including EFI & Exhaust) 4 stroke engine, EFI, and exhaust discussion |
400 FSE rebuild..will a 450 piston fit with rebore
I have decided to do a full engine rebuild to my 2002 Ec 400 FSE this winter.
So basically will the 450 piston fit with a rebore to the cylinder and are all parts from the 450 engine interchangeable with the 400, ie head, valves, clutch etc . |
GasGas was offering a 450cc kit to people that bought the 400cc bikes here in the U.S.
I'm not sure what came with the conversion. |
Thanks. Looking at the parts manual today, I can see that the only difference in part numbers is the Piston, Cylinder and Gasket. So hopefully I should be able to bore out my cylinder and fit the piston which looks like what GasGas have done from the factory, a bored out 400?
This may help some(link below). Looks like the 450 kit is a bolt on deal.
You would have to get a liner put in if you bore out your cylinder. http://www.dirtrider.net/forums3/tex...c/67908-1.html |
Vinny Austin , Tx A wonderfully working and hard riding '05 GG 450. |
Top end rebuild... | Woll | Enduro Engine - 2 stroke | 11 | 08-22-2011 07:24 PM |
PWK rebuild kit | motogroove | Enduro Intake/Carburetion - 2 stroke | 6 | 07-19-2011 06:48 PM |
Need help on top end rebuild | rpduc | Enduro Engine - 2 stroke | 17 | 03-26-2009 11:05 PM |
05 rebuild | brains | Enduro Suspension | 2 | 07-22-2008 08:54 AM |
Rebuild | steve | Enduro Engine - 2 stroke | 8 | 01-13-2008 03:06 PM |
