Enduro Engine 4 stroke (including EFI & Exhaust) 4 stroke engine, EFI, and exhaust discussion |
2007 FSR450 dash not working
The blue backlight is on but no data & bike runs fine. All connectors seem connected, but just a blue screen with no readouts.
Anyone had this happen ? Thanks in advance |
is that the ACEWELL unit?
havent had this happen but Greenland MX sell replacements cheap if its part number : BFS450634005 |
I just had the right radiator replaced. I think it may be a loose connector.
Is the pictured connector supposed to be connected ? It's on right side behind shroud by fan. I can't find the mate |
Thanks! I may look in to that if it's not just a loose connector |
Just spoke w/ dealer & they said that plug is supposed to be exposed. Must be another plug dis-connected
I had an issue with mine where the wire casings had cracked at the head unit causing the wires to touch. solved with some shrink tubing
2007 EC450FSR 2003 XR100R 1980 Z50R |
Thx, mine was rookie mistake of bad battery. Replaced battery all all was well again !
Fsr450 2007 airbox?? | BigG | Enduro Engine 4 stroke (including EFI & Exhaust) | 1 | 08-16-2013 03:51 AM |
Clark tank for FSR450 2007 | BigG | General Discussions & Announcements | 0 | 08-14-2013 08:35 PM |
2007 FSR450 - good bike? | Bike4fun | General Discussions & Announcements | 5 | 09-15-2009 05:48 PM |
Looking for input on 2007 FSR450 | floored | General Discussions & Announcements | 5 | 09-24-2008 11:03 PM |
