Old 10-21-2019, 02:08 PM
Default Top end rebuild questions
Hello All, I am in the process of replacing the top end of my 2018 XC300 and since it is my first time on this bike and first 2 stroke in a long time I figured I will have at least a few questions for the internet gods.
First question, when cleaning my cylinder I scraped all gasket material from the head including the right side power valve gasket. In doing so the gasket came off in pieces. This did not concern me because I assumed it came in the gasket kit I ordered. Well the gasket kit does have a right side powervalve cover gasket but it is paper thin while the one I cleaned off was about 4-5mm thick. I see on the parts diagram that there is a 6mm gasket shown. The question is why is this such a thick gasket and if it is supposed to be a thick gasket why would a thin one be included in the OEM gasket kit.
Old 10-21-2019, 05:29 PM
Has to be the thicker gasket, to clear the power valve actuator.
I ran into the same problem, thin one won't fit.
Old 10-21-2019, 05:31 PM
Nocams Nocams is offline
The later bellcrank assembly (2015+) protrudes further than earlier models and requires the thicker gasket for clearance.
2011 TXT300R
2018 EC300GP
Old 10-21-2019, 06:04 PM
Seems kinda dumb they don't include that gasket but oh well. Only part hanging me up now. Luckily it was in stock
Old 10-21-2019, 06:53 PM
It is.
I ordered a couple of the thick gaskets, so I won't run into that again.
Old 10-21-2019, 07:36 PM
They gave you the wrong kit buy the sounds of it. The top end kit I ordered had one in it. I will see if I can find the part number.
Old 10-21-2019, 10:02 PM
I?ve been using the back of an axp bashy (cut out with a bandsaw)for a spacer for 250hrs now. The oem items fall apart on removal.
2011 TXT300R
2018 EC300GP
Old 10-22-2019, 12:16 AM
The kit they sent is ME94620CT-CAB-1 and the only top end kit they list at Gasgaspartsguy. It is listed for 14-19 xc/ec 300
My First Top End Rebuild - A Few Questions sneaky98gt Enduro Engine - 2 stroke 12 03-06-2019 11:06 AM
Crank Rebuild Questions risk74 Enduro Engine - 2 stroke 8 11-21-2018 11:09 PM
Rebuild time questions swazi_matt Enduro Chassis & Body 5 02-10-2014 03:12 AM
Rebuild questions ram1000 General Discussions & Announcements 6 08-07-2013 07:24 AM
Top end rebuild questions bondo Enduro Engine - 2 stroke 12 02-02-2011 09:12 PM
