Clarke 3.2 Gallon GasGas Tank?
Hello chaps,
Has anyone fitted one of these to their 2 stroke gasser? What's the fitment like? Thanks |
What year bike do you have???? 07-09 bikes are a bit of a force fit but it can be done. Doesn't look perfect though at seat/tank/shroud juntion.
Go Fasters mentioned that Clarke is finally going to make a specific tank for the 07-09 bikes but no updates on this in awhile.
07 EC 300 (under 500 miles, selling soon) 97 KTM 250 EXC (sold) 2016 Trek Remedy 29er |
I have a 2006.
Any ideas what sort of tank range I'd get with the Clarke doing fairly easy trails?
2006 GasGas EC250 |
75 miles
I have an EC300 and can get about 75 miles on the Clarke tank. That was mostly really gnarly single track in the mtns of Idaho, mostly 1-2 gear. About 10 miles back on a road.
I've heard that the RB Designs squish modification will improve fuel mileage.
_________ 2005 EC300 - for sale Suzuki DL650 |
I have an 04 300(heavy flywheel) with a easy fitting Clarke 3.2 gal, and I have the RB carb and head mods.
Moderate tail speeds 5 and 6th gear 30-45mph, not in the power band. I have gone 85 miles with maybe a cup of fuel left. I filled the tank to the limit, and I'm not a heavy handed rider. With you across the pond shipping would kill ya for the head and carb mod. It made the bike more rideable, it lugs nice in the taller gears, and will still rev when you need it too.
04EC300 04Wild450 07FSR450 |
Thanks for the info guys, most appreciated.
I did a few calculations on fuel consumption yesterday. I drained the contents of my tank after a ride. I knew how far I had ridden and the tank was brimmed before I set off so I could then work out my tank range. I did 48 miles and had 2.5l of fuel left, reserve is 1l btw. With a 9l tank it gives me an approximate tank range of 63 miles. The measured mileage was 7.38 miles per litre. The Clarke tank will give me a range of about 84 miles. This was doing mostly fairly open trails with a bit of road work.
2006 GasGas EC250 |
So what's the approximate range with the factory 2.5 gal tank?
60 milesish?
2003 EC250 w/ Ohlins pkg Sometimes you eat the bear, sometimes the bear eats you. |
Well the stock tank is 9 litres - not up to speed on gallons and the range is 60ish miles on the trails that I did.
2006 GasGas EC250 |
3.1 Gallon Fuel Tank - EC300R 2010 - Any know of one? | Keg | Enduro Chassis & Body | 1 | 09-26-2009 06:18 AM |
'07 GG and Clarke Tank | Berkyboy | Enduro Chassis & Body | 12 | 01-25-2007 01:14 PM |
