Old 07-04-2011, 07:44 PM
rgranger's Avatar
rgranger rgranger is offline
Default GG 2011 300, big ass flat spot at 7k 57mpg
it just won't pull anymore, no mis, no power loss like fuel, it just won't pull past 7grand in 5 or 6th. I think that I have the 172 jet in it, filter is clean. plug looked good, real good, tried a brand new one same results. No pull after 7000rpm.
Rob
Rob Granger / Katy, TX EC300
Old 07-04-2011, 09:14 PM
Rob
Go up to a 178 main and go for a run. Its a quick and easy way to tell. Generally a lean main will just fall flat on its face and stop making power. A fat main will burble and carry on.
Otherwise could be ignition related but try the simple things first. Flick the dual mode switch? Has it ever revved past 7G or is this something new? How many hours on engine? Powervalve functioning?
Old 07-04-2011, 09:17 PM
rgranger's Avatar
don't think that I have ever wrung it out, road it about 3 times then had my shoulder re-strung. so I really don't have a good base.
i see that jd has a new set out, maybe the needles that I got back when the bike was new was not the right set?
Old 07-04-2011, 09:24 PM
The needle is most effective around 1/4 throttle and carries past half, tapering down to 3/4. From here its mostly main jet. If you are happy with the delivery up to this point I wouldn't go messing with the needle. Try out a few mains. JD kits usually require a few sizes larger than you would normally run due to the third taper leaning off again. Being a 300 you'll b lucky to see more than 9500-10000rpm out of them, but 7G is a bit too low. Up the main
Old 07-04-2011, 09:29 PM
rgranger's Avatar
thanks! I will try the jet, low end pull is good and up to 5-6 is ok, from there up very soft. will find a 175!
Rob
Old 07-05-2011, 08:13 AM
GMP GMP is online now
It should rev past that if the main is within reason (which it is) even if not perfect. Sounds like a hung up PV to me, of possibly ignition. Pop off the right side cover ans see if you get full travel of the PV.
Old 07-05-2011, 09:35 AM
rgranger's Avatar
GMP,
the one thing that I haven't busted, I mean worked on, before is the PV. Should I be able to move it about without disconnecting anything. I should be able to move the PV pivot up and down, right?
Thanks again!!
Rob
Old 07-05-2011, 12:08 PM
stainlesscycle's Avatar
you should be able to move pv easily by hand, but you will need to disconnect pv actuator rod, or you'll dislodge the balls.
07 ec300
www.stainlesscycle.com
Old 07-05-2011, 12:31 PM
motogroove's Avatar
OMG!!! Maybe I dislodged my balls!!!
-Dean
Full set of gaskets x2 coming for me. It only took me a month to order them.
Thanks to FLY Racing.
Old 07-05-2011, 12:52 PM
i definitely dislodged my balls sunday when i broke my frame and subframe on a hillclimb got bounced off the pegs and supermaned it all the way up. made it to the top and knew that it had broke.. did another lap till my kill switch rubber decided to tear and continually shock me.
gotta tear it all apart, and off to the welder it goes again.
07 ec300
Little flat spot jetfish Enduro Intake/Carburetion - 2 stroke 6 02-22-2010 01:17 PM
200 ec flat spot fishlegs General Discussions & Announcements 2 05-27-2009 05:29 AM
Nor. Cal Elkins Flat Ride 5/3/09 Rick General Discussions & Announcements 2 04-30-2009 01:39 PM
bad flat spot, Help! clerky clerk Enduro Engine - 2 stroke 1 12-07-2008 10:06 AM
battery going flat smithy363 Enduro Engine 4 stroke (including EFI & Exhaust) 3 05-12-2008 08:42 AM
