Old 07-02-2019, 05:37 AM
2smokin 2smokin is offline
Default Check your nuts! (or should i say bolts)...
Prob common knowledge but I have had many bikes and never run into this situation before, guess i will have to be more diligent about checking all the hardware on my bike before every ride (this is at 14hrs and i have lost several other misc. bolts).
Old 07-02-2019, 06:21 AM
Pygmygod Pygmygod is offline
Needs some loctite!
Old 07-02-2019, 07:50 AM
shawbagga's Avatar
Same thing happened on my '18 XC250. Felt front brake get weaker, thought it was air in the system(disc had lateral movement). Turns out 5 out of 6 front rotor bolts were loose. Loctited front & back & no probs since.
In 138 hours I've also nearly lost a pipe mount bolt(sitting on cases unbelievably), lost a rear spoke, just recently lost a chain guide bolt & a loose plug. Mostly my fault TBH.
'18 Gasgas XC250
Old 07-02-2019, 08:06 AM
I didn't feel anything in the brake but heard a squeaking that i thought was the pads getting wet (seemed to happen when i hit puddles and didn't see the screw right away). once i got home and was washing the bike I noticed the screws loose. Going to have to drill and tap the hub for the one that was rubbing, but the worst (and prob hard to see in the pic) is that it wore down the bottom of the fork and got very close to the tube, likly going to fill it in with some jb weld or something and deff lock tite the screws.
Old 07-02-2019, 09:57 AM
Don't risk your safety.
Get a new fork lug.
Old 07-02-2019, 06:30 PM
ECRider ECRider is offline
Same here. Couldn't figure out what the rattling was coming from the back of my GP300 until it stopped.
I lost the rear tail light lens.
Expensive to replace because you have to buy the whole tail light.
GG GP300 18
KTM 350EXC 17
GG EC 450, GG EC 250 08, KTM 525 EXC 06, KTM 400 EXC 01, XR400 97, VTR1000 98, VFR750 95, Husaberg FE400 96, RMX250 91, Maico 490 84, IT250J 81, RM250C2 79, Bultaco Alpina 250 77 - All sold
Old 07-03-2019, 12:30 AM
I recently bought one of these and installed as my rear lights as no lights were installed on the bike.
It's fine and serves the purpose at a cheap price:
https://www.thirdgear.com.au/univers...ke-tail-light/
Old 07-03-2019, 06:37 PM
Yeah, I checked them out before buying the OEM tail light assy.
The Edge tail kit has a tail light very similar to the original & 2/3 the price.
https://www.thirdgear.com.au/edge-ta...th-indicators/
GG GP300 18
KTM 350EXC 17
Old 07-16-2019, 09:45 PM
gg3's Avatar
gg3 gg3 is offline
Thanks 2smokin,
All my rotor bolts were loose but hadn't backed out.Never thought to check them.All sorted with Loktite.
Old 07-18-2019, 03:29 PM
a tip for picking up loose sprocket nuts (may also apply to rotors) is seeing dirty water marks radiating out from the nuts
Am I nuts? 1999 EC 250 hadfield4wd General Discussions & Announcements 134 11-14-2019 02:43 PM
Roof of Africa Guys are Nuts :) liv2day Pictures & Videos 14 12-28-2015 03:58 PM
Swing Arm/Linkage Bolts & Nuts mcnut Parts 0 12-08-2014 07:02 PM
Head tube nuts erniebearskin Enduro Chassis & Body 4 02-20-2013 10:21 AM
Cylinder Base nuts Marki Enduro Engine - 2 stroke 20 03-12-2012 10:04 PM
