  #11
Old 10-29-2020, 08:33 AM
Iakovos1 Iakovos1 is offline
Originally Posted by farmerj View Post
FYI all -
One other place where binding can happen is between Pinion Gear (#17) and Starter Gear (#20). I have seen the two gears mesh too tightly, so that when you spin them by hand they feel "notchy" vs. spinning smoothly.
What happens is that if you have a hard time getting the Starter shaft splines into the Starter Gear and use force (i.e., a rubber mallet or equivalent on the end of the Starter), it can push the two gears closer together making them hard to turn.
It does not seem like this should happen, because the Starter Gear bottoms out onto a machined lip. But there is a slight amount of play between the machined lip and the circlip on the other side.
I have inserted a thin punch between the gears when installing the Starter to make sure this doesn't happen.
Jeff
Farmer J. I believe my problem may be the pinion gear and starter gear relationship as you suggested. When I removed my old starter gear and bearing it came out as 1 pressed together unit. When I marry my new gear and bearing it is a very loose fit. My parts supplier said just put some grease to hold them together while you are pressing in new bearing and that it would be fine. After pressing in new bearing with gear, I am able to physically push the gear up and down slightly with my finger. I would think that having up and down play with the gear would be a BAD thing. Am I overthinking this?
My starter worked previously. 2019 xc300. Bought bike with 20 hours. Shortly thereafter it starter have the binding symptoms and being dumb I kept stabbing the button and blew the starter motor. Replaced with OEM unit and had 20 hours of trouble free riding. It started binding again so I bought a new motor, took everything apart to clean and grease, reinstalled with new motor and had 0 improvement. So I bought new gears, bearings, and AS3 cover. Which bring me to today.
Wet mod for 2018 starter GG221 Enduro Engine - 2 stroke 20 12-05-2022 07:51 PM
2018 ec300 starting issues! Wtf. Steveheritage General Discussions & Announcements 17 09-05-2018 07:52 AM
05 300ec Turn Signal Issues natem77 Enduro Electrical & Wiring 1 04-05-2017 05:14 PM
Looking for electric starter for 300EC 2012 oran "Wanted to Buy" & "Want To Trade" 0 01-09-2016 02:33 AM
Electric Starter pictures 2011 300EC gasgasquebec General Discussions & Announcements 70 12-04-2011 10:01 PM
