Old 04-27-2019, 06:52 AM
JBK JBK is offline
Unhappy EC300 engine/transmission stuck after oil change
Hi! The title pretty much tells the problem. But I had my bike idling right before changing the oil but now after 14 hours from changing the oil, the engine is stuck. I think I put like 50-100ml too much oil in but that shouldn't cause the whole tranny to get blocked? Should I start from taking the clutch cover off and rebuilding the kickstarter or something? Or what?
I only have 2 days to fix this so all help is very appreciated.
In advance, thanks for the help
Old 04-27-2019, 06:59 AM
gasgasman's Avatar
I would pull the clutch side inner cover off and look at the shift selector.
Could also be the crank stuffer bolts came loose.
What year bike?
Old 04-27-2019, 09:44 AM
JBK JBK is offline
The shift selector works also and all the gears go in. Could the crank really be the problem? The bike ran completely normally right before changing the oil.
And the bike is a 2013 model
Old 04-30-2019, 12:45 AM
Any news?
Old 04-30-2019, 05:07 PM
Gasser Nate's Avatar
Take the rotor side cover off and see if the crank spins. I can almost guarantee it those stupid crank stuffer bolts. I have repaired about 10 of them myself. Most painful part is the crank needs to be split to replace the smashed plastic stuffers.
Ec300 2015 transmission problem. help plz... matanstolero Enduro Engine - 2 stroke 5 06-03-2017 10:58 AM
'13 EC300 Blown Transmission bkoz Enduro Engine - 2 stroke 7 04-22-2015 11:50 AM
2002 ec300 stuck in 6th? andy176 Enduro Engine - 2 stroke 2 01-05-2014 11:57 AM
Different Transmission Ratios on EC300 ? Die Tante T. Enduro Engine - 2 stroke 16 05-06-2012 07:25 PM
Help with stuck transmission Zhack Enduro Engine - 2 stroke 6 07-05-2011 07:49 PM
