Old 03-23-2012, 06:01 PM
I agree whole heartedly. Best bet is to find a diameter and pilot that gives the best idle and off idle response. This can be done around the home in a clean environment and all the tools handy. Once thats been established you can basically run the same pilot and AS adj across the different brands OEM needles (assuming you keep the same diameter). A fat main is safe selection when testing and can later be dialled in once you find the needle taper profile you like best.
For me the following pairs of pilot and diameter work, with only subtle differences at 1/8th throttle. Leaner being cleaner.
38 - H
40 - W/I
42 - J
Old 03-27-2012, 07:02 PM
pscook's Avatar
pscook pscook is offline
38 - H
40 - W/I
42 - J
40 pilot
170 main
N3DW Second from top clip (lean)
AS 2.5 turns out
Idle screw in, but not a lot. Idle seems to fall unless I set an unreasonably high idle.
58* F
55% humidity
Runs well opening the throttle, the slightest closing it "gug-gug-gugs" but clears right up with the throttle. I will play with the AS a little, I think if I wind it out a bit more I should drop to a 38 pilot and aim for two turns out on the AS. I will drop the needle to its leanest setting first, maybe drop in the NEDJ and see how that plays with it. I have a very limited area to test, about 100 meters each direction, then I run the risk of getting pulled (or worse yet, they call my wife!). I do have a CCK to play with, how should that compare to the NEDW, NEDJ, or N3EW that I have?
Tank cracked at mounting point Bailey28 Enduro Chassis & Body 8 05-15-2013 01:47 AM
SG10 boots - how to fix a pressure point? Eric K Enduro Other... 6 11-09-2011 02:09 PM
Clutch Friction Point mcnut Enduro Engine - 2 stroke 13 05-09-2011 08:56 PM
western nebraska on a '98 Pampera mudwasp Ride Reports 0 02-13-2011 10:50 PM
What is the point of the bolt on the side of the head? Motarded1 Enduro Engine 4 stroke (including EFI & Exhaust) 1 02-03-2009 06:17 PM
