Old 08-05-2013, 10:23 PM
pscook's Avatar
pscook pscook is offline
Originally Posted by AZRickD View Post
Wow. I think I made the right decision.
Anxiously waiting for your report. Well, sorta. Yeah, pretty much interested in how it works. Current folding money is set aside for repairs, but future mad money needs a reason to stew.
Phil
(New bike pending...)
Old 08-05-2013, 10:34 PM
AZRickD AZRickD is offline
It will be built tomorrow or so and shipped. I am going to work on the Rekluse adjustable slave, racing number plate mount and graphics.
Lectron will be tackled next week.
I asked Mr Lectron about that plastic airboot-to-carb adapter that is on my '11 GG. He said be was vaguely familiar with it, but hadn't heard of any fitment issues.
Will I be removing that or keeping it on?
I was thinking about gearing down one tooth in the front. I wonder if the mambo torque of tbe 36mm Lectron will dissuade me?
Old 08-06-2013, 12:04 AM
singletracker singletracker is offline
I would wait on gearing it down until after you get the Lectron installed and adjusted. I'm guessing you'll decide not to gear it down after trying it.
If you are refering to the plastic adapter that is fitted to the stock carb you won't need to put it on the Lectron. At least I didn't.
2011 250xc Race
Old 08-06-2013, 06:12 AM
fasteddy fasteddy is offline
I've also put the 36 lectron on my 2011 250 Race, the carb adapter stays with your stock carb, the lectron fits way better as is... I'm pretty happy with the 36, have gone back to 13/48 gearing, lots of low end grunt and pretty linear power delivery..Still having some issues right at the bottom, either to rich or to lean, The 1/4 turn adjustment just seems to big to fine tune the bottom. Am looking at getting Lectrons new rod. Looking forward to your report.
Ed..
2011 250 Race, kicker...
2006 640 KTM Adventure...
Smartcarb... Done Waiting, maybe later... Lectron... Got one..
Old 08-08-2013, 06:03 PM
StuJohnson's Avatar
StuJohnson StuJohnson is offline
What did I do?
So I leaned out my Lectron by extending Rod. 1 kick and it starts.
Idle seems to be stuck. I turn adjustment out but idle stays the same.
Any thoughts?
2012 - XC 300 Racing
Seattle, WA
Old 08-08-2013, 06:18 PM
You sure that high idle isn't the engine racing from being a bit too lean?? pull the choke for a second and see if it drops. You could also look in the intake and see what height the slide is sitting at, or remove the slide and check the action of the grub screw for the idle speed. I also recall some intial wear on the slide where it stops against the screw. Double check this hasn't got too much burring on it. A good tip is to lift the slide (open the throttle a bit) when making idle adjustments, as it takes the weight off the slide.
Old 08-08-2013, 06:23 PM
StuJohnson's Avatar
Well......I think you nailed it on the head!!!! I pulled the choke and the idle drops and then the motor dies.
At least it makes for an easy fix
Just need to figure out how much I should turn back in....
Thanks
Seattle, WA
Old 08-08-2013, 11:07 PM
pscook's Avatar
Thanks
38mm or 36mm for the 300?
Phil
Old 08-08-2013, 11:12 PM
StuJohnson's Avatar
Kelly got me the 38mm for my 300.
We discussed this and he says that the difference would be minimal... But AZRick says a bit different.
Seattle, WA
Old 08-09-2013, 12:18 AM
I spoke to him about the 36 vs 38 on my 250 and the fact that I'm a short-shifter and that I want more bottom the Keihin already gives me all the top end I want.
He agreed with my hypothesis that the 36 would suit my needs.
However, if I were on a 300, based on the 300s that I have ridden, I would go with a 38 for that bigger bored bike.
I'm just tailoring the bike to my needs, not attempting to assume that my quirks would fit the majority.
Lectron Carb singletracker Enduro Product Reviews 145 07-27-2013 12:20 AM
Smart carb my review Diggs345 Enduro Product Reviews 9 11-28-2012 03:28 PM
RB-Designs carb mod or PowerNow? AZRickD Enduro Intake/Carburetion - 2 stroke 14 01-23-2009 05:50 PM
RB Designs Carb Mod Magellan Enduro Product Reviews 18 06-11-2008 01:44 PM
RB Designs Carb Mod? Boomhauer Enduro Intake/Carburetion - 2 stroke 4 03-20-2007 03:09 PM
