2011 TXT 300 GG starting propblem
Hi Guys,
My 2011 GG TXT 300 is not starting and was running great up until, I turned it off and now its not starting. Good gas, clean air filter, good spark, reed valves is in great shape and compression is good. When kicking the bike over, it feels very different and I am not able to give it the hard kick that?s needed for it to start up. Just looking for some help on troubleshooting this problem, as I am new to gg Trial Bike. Could the Kickstarter gear be worn-out and require replacement? Any help will be greatly appreciated. Thank you |
Can you push start it? If so, how does it run then?
That is a great question.
Its my first trial?s bike. Due to high compression and the gearing, it's very difficult to push start this type of bike to the best of my knowledge. Thank you for your help |
have someone push you and you stand on the pegs and then dump the clutch. |
https://www.trialscentral.com/forums/
Trials Central if you scroll down as a gas gas specific forum some very knowledgeable gas gas trials guys they'd be glad to help you out. This is more of a off-road forum
02 EC 200 03 MC 250 88 VT 800 01 TXT 280 |
2018 ec 300. My bike is not charging the battery. I have cleaned all connections and checked all grounds and two fuses that i an awRe of. Any thoughts? Im assuming the stator is buggered up but, i no nothing about this
Get the charge rate measured straight out of the regulator, (still plugged in) I bet you will have voltage drop issues. Get a proper auto electrician to sus it if out of your depth.
You can do voltage drop tests from the negative and positive feeds out of the regulator to where the drop is if so. My mates was losing about a volt across the light relay.
Back on a gassy! 2018 EC300! 🤘 Txt 280 07 to make me feel like a gumby again |
Thread Tools | |
Display Modes | |
Starting point for N3CJ on 2011 ec 300. | Quigs | Enduro Intake/Carburetion - 2 stroke | 10 | 02-08-2017 02:42 PM |
starting a 2011 EC 300 part out. | redrider | Parts | 28 | 08-08-2015 02:11 PM |
2011 txt 300 starting when hot | Glenn | General Discussions & Announcements | 1 | 02-23-2013 04:24 AM |
Hot starting. | nick790 | Enduro Intake/Carburetion - 2 stroke | 0 | 04-21-2010 02:44 PM |
F-1 Starting! | Rick | Pictures & Videos | 6 | 12-18-2009 08:14 PM |
