Old 09-12-2019, 02:16 PM
We did a mates last month. Only thing that got it fixed was a new needle.
I drop a ball bearing in the seat and tap it to ensure the hole is round.
But do take your tap out and clean any tank grit. A hair will hold the valve open.
Old 09-13-2019, 04:26 PM
I have had good luck chucking up a cotton swab (Q-Tip), dipped in polishing compound (tooth paste in a pinch) into my electric drill. You can use this to polish the carb seat mating surface so the needle's Viton tip has a smooth surface to mate with or (with which to mate if you are opposed to ending sentences with prepositions) ;-)
https://www.quickanddirtytips.com/ed...-a-preposition
Is it Friday yet?
Old 09-13-2019, 04:44 PM
rodent's Avatar
rodent rodent is offline
Actually, it's Saturday morning
Old 09-13-2019, 08:13 PM
Is it Friday yet?
This works brilliantly. We used autosol at the bike shop when we had grungey corroded carbs that were sitting around for years in the jap imports.
Old 09-13-2019, 10:16 PM
We replaced the seal/ball bearing tap after he'd tried this trick.
Ohlins Forks 46mm Leaks Leaks and more Leaks Zman Enduro Suspension 8 09-03-2017 07:42 AM
Fuel dye jerry623 General Discussions & Announcements 2 11-24-2014 08:34 PM
no fuel efi stockton Enduro Engine 4 stroke (including EFI & Exhaust) 1 08-08-2014 12:37 AM
fuel & oil knobbyboy Enduro Engine - 2 stroke 4 07-20-2014 05:37 PM
Fuel range and fuel light sanderjavant Enduro Engine 4 stroke (including EFI & Exhaust) 6 01-05-2008 02:35 AM
