Old 01-17-2016, 03:10 AM
twowheels's Avatar
Originally Posted by swazi_matt View Post
I thought I had no issues with this when I installed the CP impeller but obviously I was wrong
Although I don't think I should do anything considering I have at least 150 hours of hard rock riding since installing it. Maybe just clean it up with a dremmel stone or sandpaper?
Well done - you've provided Mr. Webster a picture for his dictionary for "self-clearancing parts".
I'd clean both the cover and the impeller up a bit and provide just a little extra clearance in the chance that you tag a rock with the cover or over-snug the cover screws ... it may even feel like you've gained a few horsepower when you're done.
Steven Beane #275
afterhourscycle.com
Old 01-17-2016, 03:12 AM
Most the water pump covers look like that Matt. Pretty sure that's how they are machined during manufacturing.
Your impeller however looks like its made some contact. Is it as rough as it looks or does the picture make it look worse?
I'd clean them up a tad and check the clearances again with some grease/paint/marker and then see how it all looks.
Old 01-17-2016, 07:37 AM
shultzy shultzy is offline
I would also suggest using a thicker cover gasket or stacking 2 regular gaskets to give yourself a little extra clearance and peace of mind.
Old 01-17-2016, 12:19 PM
swazi_matt swazi_matt is online now
Definitely been in contact. The photo makes the tops of the vanes look smoother than they are.
Think I will just sand them down until they are smooth again. Probably do it manually to avoid any overexcitement accidents with the dremmel
Old 01-18-2016, 12:29 AM
twowheels's Avatar
The issue is clearly a QC one - the gasket surface is not perpendicular to the "cone" for the impeller. There may have been some attempt to correct this at the supplier (I too have seen some new covers with a half swath of tooling marks inside) but the aluminum impeller just got into it more.
You would think that if all else is equal the impeller would want to avoid the cover, but perhaps the pitch/sweep of the impeller blades drives it outward, or if the water pump shaft and gears aren't exactly parallel to the crank the water pump shaft may be being forced outward when the motor runs.
Steven Beane #275
afterhourscycle.com
Old 03-15-2017, 04:19 PM
SpirosZ1000's Avatar
SpirosZ1000 SpirosZ1000 is offline
I came across this thread because I wanted to install the checkpoint impeller to my 2015 300 ec.
For the record I had come across the nasty problem of the broken inner bearing which lead to the broken shaft in my 2006 ec 300 and when I opened it I found also that the plastic impeller was rubbing to the cover. Problem solved with the motocross center kit but after investigating the problem with my mechanic (also a close friend of mine) we came to realize that it wasn't the impeller the problem.
If you look closely to the shaft it has a grooving just before the part that sits inside the inner bearing just like the one it has after the plastic gear where the safety pin sits and holds the gear in place. In the inner grooving it has no safety pin 2006 and 2015 model as I found today. In my 06 we had come to the conclusion (thing about what you where saying about shaft braking when bike fell to that side and took a hit there!) that the bearing had taken his fare share of use and as the engine run and heated up the "nest" that the inner bearing sits loosened from heat and with nothing holding the bearing in place when the bike came to down to this side it had many chances to slip to the shaft and come out of place causing all the rest to go wrong.
Problem solved by adding an extra safety pin to the shaft before installing the cover back in place and then installed motocross center kit and let me tell you that this bike even when I was a newbie and with the hot weather we see 6 months of the year here in Greece it never spilled a drop of coolant again not only to me but also to my buddie who bought it.
Now it's time for the 2015 ec 300........ motocross kit doesn't work out of the box because the outer WP cover is different so it's checkpoint impeller for me this time. the next few days I will take pictures of the work in progress and also from what I am doing to the shaft with the extra pin.
Gas Gas EC 300 2006
Gas Gas EC 300 R 2015
Gas Gas EC 250 GP 2018
Old 03-16-2017, 04:22 PM
Gas Gas EC 300 2006
Old 03-16-2017, 04:25 PM
Checkpoint impeller installed without any rubbing what so ever so I guess I am lucky.
Photos added with the last one showing the extra clip I used to the shaft to prevent the bearing movement.
Gas Gas EC 300 2006
water pump seal gassergrant Enduro Engine - 2 stroke 5 06-20-2012 04:04 PM
water pump? nhrider Enduro Engine - 2 stroke 17 12-21-2008 12:05 AM
Water pump seal brains Enduro Engine - 2 stroke 2 07-26-2007 10:25 PM
water pump impellers splint General Discussions & Announcements 2 07-24-2007 07:20 PM
cooling pump shaft lufc Enduro Engine - 2 stroke 11 05-25-2007 05:42 PM
