Old 08-31-2010, 04:36 PM
timlh's Avatar
timlh timlh is offline
Default 2001 XC300 Wheel inter change info needed
Hi, Does anyone know what other year Gassers use the same wheels as my 2001 XC300. I know the front rims are the same from 97-07 based on info I found on Excels web site. But are the hubs, Axles, etc common for multiple years.
Thanks, Tim
Old 08-31-2010, 06:00 PM
GMP's Avatar
GMP GMP is offline
Although the hubs changed in '03, the rears from all years will fit. Axels also. For the front check the part #s of the hubs. In '04 they went to Zoke forks and a different axel, but I think the hub is the same. For sure XCs (WP forks) from '00 through '03 EC/DE are the same front.
Old 08-31-2010, 07:25 PM
gasser's Avatar
gasser gasser is offline
I run an 01 rear wheel on my 07 gasser sometimes but I have to run some shims to make it work. The hubs and axels are apparently the same but the spacers and one bearing is different.
2001 XC300 Rod kit timlh Enduro Engine - 2 stroke 3 07-15-2010 05:12 PM
Help! Wheel interchange info '05 DE300 DBR0051 General Discussions & Announcements 1 06-27-2009 10:02 AM
MC65 rear wheel bearing change bergerhag Enduro Chassis & Body 0 03-12-2008 03:16 PM
