#191
I'm surprised you could even get the water pump cover on with the checkpoint installed. Not a chance on my 2010.
#192
I had done the very same,took the impeller to a machine shop. There's limited
material that can be taken from the back side of the impeller,This worked fine on one bike,(200) The other impeller was machined and still made contact so I fabed a spacer from an old skid plate,that was less than 3/16''. Has worked fine since.Best of luck. John |
#194
#195
Looks to be a least the right case side?? ouch for sure.
'12 XC 200 TTX Sold '15 XC 250E Sale pending |
#196
And Main gear. took 8 months for parts.
Rob Granger / Katy, TX EC300 Breaking more things by 8:00AM than most people break all day. |
#197
I have managed to fix the casing. Bought new bearings, found water pump shaft and gear in spares box. Everything was less than 20euro
Hope i will be riding next week without other disasters |
#198
I thought I had no issues with this when I installed the CP impeller but obviously I was wrong
Although I don't think I should do anything considering I have at least 150 hours of hard rock riding since installing it. Maybe just clean it up with a dremmel stone or sandpaper?
#199
Gear on the back looks fine
Anyone tried stacking two oem gaskets to add space? (maybe the old one and a new one?)
#200
My stock plastic impeller looks to have rubbed the cover for the last 15 years. I think it has given itself clearance long ago by doing this. I would personally keep running it and just polish the inside of the cover and maybe the top of that impeller.
I am still learning a lot about these bikes and working on them, so take my advice with a grain of salt. Having said that, I don't see anything to be concerned. After 150 hours, it has sorted itself out. Just polish and ride on. |
water pump seal | gassergrant | Enduro Engine - 2 stroke | 5 | 06-20-2012 04:04 PM |
water pump? | nhrider | Enduro Engine - 2 stroke | 17 | 12-21-2008 12:05 AM |
Water pump seal | brains | Enduro Engine - 2 stroke | 2 | 07-26-2007 10:25 PM |
water pump impellers | splint | General Discussions & Announcements | 2 | 07-24-2007 07:20 PM |
cooling pump shaft | lufc | Enduro Engine - 2 stroke | 11 | 05-25-2007 05:42 PM |
